05-07-2008, 01:59 PM | #1 |
Fanatic
99
Rep 175
Help Identifying problem..
The front end on my '01 530i is feeling a bit loose.
When I let go of the wheel it will pull a little to the left or a little to the right, depending on what it wants to do. Holding the wheel steady in a turn, I have to correct a little bit even though I judged the turn perfectly. It's as if the wheels are moving/changing angle while in the turn. (Reference.. on turns like in this pic.) The pull is unpredictable, I have to sit there and constantly let go then correct the wheel again to try and get it to go in a straight line on its own. In most cars to me it is stiff and apparent where this sweet spot is. (Dead center of course) Today I let go and it drifted a little bit to the right, and then quickly drifted faster to the right a few seconds in out of nowhere. After accelerating to around 45mph the steering wheel will also start to shake left and right fairly fast like as if going over a ton of bumps, but then goes away after a short bit. It started up about a week or so ago and I haven't hit anything to my knowledge, I figured it might go away after a little while.. -___- The only thing I can think of that might affect the front end is for the past two months I've been having to drive over a long 2x4 in my driveway. Its angled diagonally in the driveway so all of the wheels go over it at a different time.. Do you think the simple solution is just an alignment, or could it be something else?? -Nathan
05-07-2008, 02:02 PM | #2 |
Rep 920
Drives: 06 E90 330i 6MT, 01 E46 330i
Sounds like front control arm bushings need to be replaced.
Mar 05 Build date,2006 E90 330i, Sport Package, Premium Package, TR MT-1's . V-1 Hard-wired power with custom V-1 Concealment Display . Rear fogs, Rear power outlet's, M short shifter knob, BlackLines, BMW Strut tower bar, CDV Delete, Front M3 wishbones + tension struts, BMW Performance shocks and springs, BMW Performance Brake kit F&R, OEM short shift kit. Rear M3 Guide rods and Wishbones.
2006 E-90 330i with 302,000 miles. |
05-07-2008, 02:20 PM | #3 |
Fanatic
99
Rep 175
Hmm.. that would make sense, the car is at around 51k Miles..
http://www.understeer.com/lcab.shtml Thanks for the help!! If anyone else has any opinions on what the problem could be, I'm open for suggestions. However, I think that Richwm hit the nail on the head. An estimate of the cost to repair it would be much appreciated as well. -Nathan
05-07-2008, 07:51 PM | #4 | |
Rep 920
