F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > BMW 3GT F34 Battery location
ARMA SPEED
      02-03-2015, 09:15 AM   #1
bhanvadia
Drives: BMW 320d GT
Hi friends, I am trying to disconnect -ve from battery in my BMW F34, but unable to locate battery.
Can anyone help on this, post pics of location or guide me to do it?
Thank you
      02-03-2015, 09:32 AM   #2
ELNch
Norway
Drives: Bmw 320iGt xdrive M-sport
IT is in the trunk
      02-03-2015, 09:42 AM   #3
bhanvadia
Drives: BMW 320d GT
Can you specify where in trunk?
Left side panel of trunk have first aid kit and tailgate motor. That is all I can open. Do I need to remove some bolts/screws to get to battery?
Please help with pics if possible.
      02-05-2015, 11:09 AM   #4
eyedoc
eyedoc's Avatar
Sweden
Drives: 530d '14 F07
look at opposite side (right), try to pry this small trim cover in luggage compartment's floor on the right hand side, comes off quite easily, there can you see battery but to be able to get any closer to it, may be difficult...
      03-20-2015, 06:27 PM   #5
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I finally found it, out of curiosity. The small floor section behind the right wheel well pries off, and you can see the battery underneath.
      03-23-2015, 11:06 AM   #6
FabioCipriani
FabioCipriani's Avatar
Brazil
9
Drives: 2019 330i M Sport (G20)
Have the same question. Seen the same hole in the floor where you can see the battery underneath... but honestly, the only way I've seen possible to get to the battery is to remove the whole cover below the trunk (the space where you can accommodate the trunk lid trays)...
Still wondering why the hell they made it so inaccessible...
Wanted to disconnect the battery because I'm traveling away for a couple of weeks... looks like I'll need to call for help in case the battery drains out...
      03-23-2015, 11:58 AM   #7
Billfitz
Billfitz's Avatar
Unless it's a lot colder than you'll ever experience where you are the battery won't drain in two weeks. Two months, maybe.
      03-23-2015, 05:11 PM   #8
Benmychree
United Kingdom
Drives: 320d GT F34
I am glad I saw this. I had only just bought the car and got flagged down by a lady looking for a jump start. Imagine our surprise when I opened the bonnet and .....nothing.
      03-23-2015, 05:33 PM   #9
Billfitz
Billfitz's Avatar
Now go open your owner's manual.
It will show you where the connection points are under the hood to jump start your car, or to use your car to jump start someone else.
      03-23-2015, 05:57 PM   #10
smithf80
smithf80's Avatar
Drives: G80 M3 6MT
2022 G20 330i  [9.00]
2018 F80 M3  [9.75]
This. Always use the points under the hood. Don't even try to hook to the battery directly.
      03-23-2015, 07:17 PM   #11
Benmychree
United Kingdom
Drives: 320d GT F34
Billfitz, if you managed to read the manual cover to cover within 2 days of buying your car, you are a better man than me. Or you have a lot more free time than I do!
      03-23-2015, 08:58 PM   #12
Billfitz
Billfitz's Avatar
I read it two months before I bought the car. I also watched every video tutorial, most at least twice, so that when I took delivery I'd know how to use all of its features. Even then figuring out the idrive took some time, it's not exactly intuitive. I've always taken the Boy Scout motto seriously.
      03-24-2015, 09:36 AM   #13
ipilcher
ipilcher's Avatar
445
Drives: 2024 M3 Compensation
I gave up on my owners manual when I realized that at least 50% of it doesn't apply to my car, and there's no way to determine which 50% it is.
      03-24-2015, 03:00 PM   #14
Mike_L
Drives: 2015 335xi GT M-Sport MPPK
Use the iPhone one. Its based on your VIN, so everything it has in there applies to your car.
      01-15-2023, 01:49 PM   #15
RHBBMW
Drives: E46 325cic, F34 340 GT
Billfitz I have a 2017 340 GT and can not find the battery. Can you post a picture of the battery location showing the panel that needs to be removed?
      01-15-2023, 02:45 PM   #16
Billfitz
Billfitz's Avatar
The floor directly behind the right rear wheel well pries up. You need to use three plastic trim removal wedges to spread pressure along its length. Once that's pulled you'll see the battery down below.
      01-16-2023, 10:16 PM   #17
SupremeF34
I make videos for all things F34 !
55
Drives: ’18 F34 340i GT
I have a 2018 340 GT. I know you asked for a picture but here’s one better. Skip to 1:47 for battery disconnect. Happy wrenching!
https://youtu.be/pazS6RsUbSc
      02-06-2023, 01:36 PM   #18
shrey94
Drives: 330i GT XDrive
I am not able to find it, please somebody help me with pictures.
      02-06-2023, 02:37 PM   #19
Billfitz
Billfitz's Avatar
Supreme F34 showed you pictures, video no less. Watch it, starting at the 1:47 mark.
      02-06-2023, 08:28 PM   #20
18340GTFNG
Drives: 2018 340GT
Sort of related questions, I heard somewhere that the cars computer tracks the lifecycle of the battery and adjusts the charging algorithm accordingly. Is that a real thing that actually makes a difference? Is there a manual reset for that through the dash or is that something that has to be done at the dealer?
      02-06-2023, 10:14 PM   #21
Billfitz
Billfitz's Avatar
It is real. You only have to be concerned if you get a new battery, at which point you have to register it in iDrive so that the car knows that it's new and doesn't over-charge it. Many OBD diagnostic and repair tools have the capability of registering a new battery, many battery retailers will do it for free. Dealerships however have been known to charge up to $150.
      03-23-2024, 07:17 PM   #22
Gran_Turismo
Drives: 328i GT M Sport
I have a 2016 328 gt, does anyone know if it's a 12v agm? I'm trying to figure out which setting to use on my battery charger/maintainer. Thank you
f30post
