06-26-2019, 07:24 AM | #1 |
Cheapskate
4464
Rep 4,995
6MT Clutch Strength
Goals for my build are to have maximum efficiency out of my car. I don't need to have the fastest car in town, but I don't want to feel like I'm leaving a lot of power on the table. But one of the big things I don't want to do is move to a heavy aftermarket clutch. Some people discussed that the 550i clutch might be a possible OEM+ upgrade, but that'd be as far as I go.
So just curious, has anyone experienced clutch slip after turning up the power?What tune are you running, and how much power/torque are you putting down? Anyone on upgraded turbos with stock clutch? And can anyone verify the 550i clutch bolts up? Maybe we have to reuse our flywheel or maybe we only need the 550i pressure plate....idk. For reference, I'm currently on BM3 Stage 1 93 oct with no issues, looking forward to bumping up to e30 or e85 within the next year. I'm hoping that with the style of tuning that PTF used in V2.0, I can continue to turn it up more with less risk of clutch slip since torque onset is smooth and progressive. |
06-27-2019, 06:30 AM | #2 |
Rep 606
Subscribed. Good to know you are not slipping with stage 1. As a 6mt owner, I was surprised to see that the MPPSK upgrade was downgraded for 6mt cars vs ZF8 cars. Could not find a rationale published, but deduced it was concerns over transmission or clutch longevity. That said, was talking with active autowerke this week and they said the 6mt could take more power than the zf8??
kern4174464.00 thebonafortuna4.50 |
06-27-2019, 08:50 AM | #3 |
Rep 521
So, I don't have any slipping, but I do have juddery engagement occasionally in first. It's weird and intermittent. The dealership couldn't duplicate it, so nothing has been done about it. Based on research, I suspect it is either a failing clutch (as in, the springs involved in the dual-mass system are failing), or it's the 'automatic adjustment' not adjusting smoothly, so it gets slightly 'out of adjustment' and judders for a day or two, and then the adjuster gets un-stuck and it's adjusted properly again and it acts normal again for a couple weeks.
I'm at 54k miles, MPPSK since day 1, and most of the time I don't even drive it hard. I've been to the drag strip once (3-4 runs?), done maybe 2-dozen other launches, and mostly it's my commuter car... without a ton of stop-and-go traffic, mostly flowing highway traffic. If I go with a tune, I'll update this thread with my experience. The most aggressive I would go is stage 2 though, I won't be doing upgraded turbos or anything like that. |
kern4174464.00 |
06-27-2019, 11:16 AM | #4 | ||
Cheapskate
4464
Rep 4,995
I also have 2.5° of camber in the rear, so i'm *hoping* my tires will break free before my clutch is overloaded. I chirp tires during shifts sometimes but honestly have no problems hooking low gears with 275 summer tires, even with traction in dynamic mode it barely spins if at all. |
06-27-2019, 05:07 PM | #5 |
Rep 40
Drives: BMW 340iX 6MT Msport
I saw that there may be 2 types of manual transmissions, by ZF and Gretag. How can you tell? or is it by model year?
06-27-2019, 10:07 PM | #7 |
Rep 1,449
06-28-2019, 05:07 AM | #8 | |
Cheapskate
4464
Rep 4,995
How are you managing it? Are you planning on upgrading or is the slip intermittent? |
07-07-2019, 10:55 PM | #9 |
Rep 168
I am running MHD stage 2 91 octane. While the clutch doesn't slip with WOT, it is defiantly not strong enough to launch the car aggressively with an xDrive. In my experience you can't rev it much past 2500rpm when launching and need to just slightly slip the clutch. Too much RPM or too much slippage and the clutch won't grab. I did not try to launch when stock but I suspect result would be the same.
kern4174464.00 |
07-09-2019, 06:15 AM | #10 | |
Rep 521
I've only done that on plain pavement, never on a prepped drag strip though - last time I was at the strip the car was too new and I was pussy-footing it. |
10-02-2019, 01:56 PM | #11 |
Cheapskate
4464
Rep 4,995
I upgraded to Stage 1 E30 a few weeks ago and so far so good. My buddy on Stage 2 E30 + meth did just upgrade his clutch though due to it slipping.
Any other feedback? |
10-04-2019, 05:31 AM | #12 |
Cheapskate
4464
Rep 4,995
bump
10-04-2019, 03:09 PM | #14 |
Rep 398
The clutch is only interested in torque (hp is calculated based on torque and rpm) so with a big turbo you normally don’t add a lot to the torque max but to the torque/HP high in the rpm.
The best indication would be a tuned Diesel engine (torque monster). Maybe look into what European tuners do with a 335d (or whatever the top model is called) and then use this as your limit. A good tuner will be able to keep you under the limit but still give you max hp. As the max torque is around 2-4 and the it drops off. |
10-05-2019, 04:16 AM | #15 | |
Cheapskate
4464
Rep 4,995
10-06-2019, 03:37 PM | #16 | |
Rep 521
How you engage the clutch, how you apply throttle at the same time, how long you let it cool down between hard launches, do you 'bounce' on it while stopped on a hill... all those and more impact the ultimate reliability and performance of the clutch. The owner of a local shop only ever buys manuals if he can help it, puts crazy high torque mods on his car, and generally doesn't have problems with clutch slippage, because of the way he drives. Other people with the same cars complain about clutch slippage at stage 1 or 2. As with everything, if you're going to modify your car, be willing to pay for stuff that breaks because of it. If with the way you drive the clutch starts slipping, either take off the power mod, or upgrade the clutch. |
10-07-2019, 06:22 AM | #17 | |
Cheapskate
4464
Rep 4,995
If your clutch is just fried, then yeah. That's a different story. |
10-07-2019, 10:56 AM | #18 |
Cheapskate
4464
Rep 4,995
According to Real OEM, every BMW since the E90 has had the same clutch. The recommended upgrade is from an e90 335is/F10 550i. It's only about $330 on FCP Euro (Free lifetime replacement) so that's probably the route I'll go before getting tuned for more power.
Part #21207603248 https://www.fcpeuro.com/products/bmw...uk-21207603248 |
10-09-2019, 06:23 AM | #19 | |
Rep 521
kern4174464.00 |
10-09-2019, 08:24 PM | #20 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
BM3 OTS E30 Stage 2 was the limit for mine.
I thought it had only slipped a few times but when the box came off the flywheel looked like this. Car has been tracked 9 times in 2 years, and a few burnouts but mostly just daily driving. |
10-09-2019, 09:13 PM | #21 |
Rep 1,449
Looks like we'll need a full stage 2 clutch upgrade including flywheel. I was really hoping I wouldn't have to go single mass because of chatter.
10-10-2019, 03:18 AM | #22 |
Cheapskate
4464
Rep 4,995
unless you plan on going much further, i still feel like the 335is/550i clutch is a viable upgrade for the majority. Tracking 9 times in 2 years is a lot more aggressive driving than most of us do. He needs a clutch that can handle the added heat.
