F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > BMW 440i Fueling & Drivetrain Malfunction
GetBMWParts
      01-06-2022, 12:47 PM   #1
alexander7599
Alexander Hartunian
alexander7599's Avatar
Drives: 2018 BMW 440i
2018 BMW 440i  [0.00]
Exclamation BMW 440i Fueling & Drivetrain Malfunction
2018 440i w/ 27700 miles
Installed a catless downpipe and Dorch stage 2 HPFP, let prime and tuned to stage 2 with HPFP calibrated. Everything was torqued to spec and triple checked, no leaks. Started the car with a long crank to a rough idle as expected except that it didn't go away. We replaced all 6 spark plugs to brand new NGK plugs to rule that out, misfire codes went away but still getting DTM after starting the car. Which leads me to believe it has to do with fuel pump calibration within the tune (we have tried multiple different tunes) or it has to do with the low pressure fuel pump not supplying the high pressure pump with ample fuel. However a buddy of mine with a 340i has the same setup and none of those issues.
The car runs fairly smooth above 2000 rmps but fails to get enough fuel near idle rpms.
My live data shows lambda idling around 15.7
Codes Thrown:
From BM3:
11AC02 - High-pressure fuel, plausibility, cold start: pressure too low
118401 - Mixture ECU: mixture too lean, excessive deviation
11A401 - High-pressure fuel injection upon release: too low pressure
From Carly:
11B401 - High-pressure fuel at or after the release of injection (second environmental condition set by time delay) to low pressure
11A030 - Fuel low pressure system, electric pump adaptation: adaptation value out of valid range
What I think:
catless downpipe O2 sensor
bad fuel injector
LPFP
Any and all help would be greatly appreciated. I am sort of lost at this point, short of throwing the stock pump back on and rolling with just the downpipe.
Thank you very much.
2018 F32 440i - Black Sapphire Metallic - KW Suspensions V1 | VRP Intake | VRSF Catless Downpipe | Dorch Stage 2 HPFP | MHD OTS Stage 2 E40
      02-03-2022, 06:51 PM   #2
Senhorcheeks435
Senhorcheeks435's Avatar
Drives: Bmw 435 GC
2015 Bmw 435  [0.00]
I'm driving. F36 fbo .. my problem was the hpfp fuel pump throwing the bank 1 now I got that replaced it runs like a dream with no code
      02-05-2022, 08:27 AM   #3
Uni-Rapide
Uni-Rapide's Avatar
Netherlands
71
Drives: 2019 F30 340i
Codes Thrown:
From BM3:
From Carly:
What I think:
bad fuel injector
LPFP
Don't know if your still have this issue but my best guess is there is something wrong with the HPFP you installed. As that is what you changed and you have HPFP related error codes.
Mods: 19" HRE FF15, M Performance diffuser, Bilstein B16 Damptronic, VRSF catted downpipe, Remus catback, Dorch St1, Pure 800, OS Giken LSD, Ross Racing PCV+OCC V1
      02-21-2024, 07:42 AM   #4
NickNack11
Drives: BMW 440
Codes Thrown:
From BM3:
From Carly:
What I think:
bad fuel injector
LPFP
Any and all help would be greatly appreciated. I am sort of lost at this point, short of throwing the stock pump back on and rolling with just the [...]
Were you able to figure out what the issue was?
f30post
