03-25-2024, 12:50 AM | #1 |
Rep 416
Oil stains on a driveway
I am looking for a way to lessen old oil stains on a concrete driveway. Tried 130bar jetwash with no avail. I've tried brake cleaner before briefly but got convinced it has no effect. Now thinking of flipping slabs to the other side.
1995 E34 525td auto 2016 F30 320ed auto
03-25-2024, 03:43 AM | #2 | |
Idiotic lifter of heavy stones...
2018
Rep 2,199
Drives: 2015 F31 325D M Sport touring
Like you I tried everything on my folks driveway when my Mum's BMW E46 330Ci started leaking (as all M54s do) many years ago... Got rid of most, but there was always a mark there and when it rained; it always formed a waterproof patch
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
Allworth221.50 |
03-25-2024, 05:33 AM | #3 |
Rep 543
Could you brush some oil onto the rest of the slab?
Maybe make a pattern of slabs? Or does it not stain evenly? Just an idea before flipping the slab. You can bet the other side will be a slightly different colour.....
335d xDrive
danb19792018.00 |
03-25-2024, 11:32 AM | #4 | |
Rep 2,055
If there are still stains then you can help cover them by sprinkling cement powder onto the area on the slab that's stained. |
danb19792018.00 |
03-25-2024, 03:54 PM | #6 |
Rep 2,010
Drives: F30 335d
I have several oil stains from when the oil cooler was leaking, the car doesn't drip oil anymore. Tried gunk which helped a bit. Good tip for the cement, I'll give that a go.
03-25-2024, 07:22 PM | #7 |
Rep 2,055
I hope that works, if it does it might just be the easy option. I got roped into helping a mate once do that. Not for oil stains but just general marks and such on a property he'd moved into. Turned out that whatever they'd laid it on had stained it worse than the marks on the topside! I suspect it was old shale oil spoil and the remaining oil from there had seeped into the slabs. I declined his kind offer of me helping to return them all to the original side up!
Allworth221.50 |
03-25-2024, 07:44 PM | #8 |
Rep 1,770
Paving slabs have a 'good side' and a 'bad side' though. The underside usually has 'dimples' so it will show and look almost as bad.
I have the same problems with brick sets and an old coolant leak. Every time it rains, the coolant rises to the surface again and stays for weeks. The ONLY cure is to replace the affected slabs, as the oil or whatever will have soaked into the whole thing and there is no getting it out. You could try setting fire to the slab, but it will eventually explode. Ask me how I know! |
Allworth221.50 |
04-10-2024, 02:19 PM | #12 | |
Rep 416
Brick cleaner has a hydrochloric acid as an active ingredient, while it does good job removing mortar residue it does nothing to oils.
04-11-2024, 03:32 AM | #13 |
Rep 101
Soldiering torch is weak. If you have a family member or friend who does roofing or central heating they should be able to help you. Buy them a drink
Honestly best way |
04-18-2024, 04:54 AM | #14 |
Rep 969
possibly a daft question - have you tried dish soap? seems to be all they use to clean up birds etc after oil spills in the ocean.
not quite engine oil but i had decent luck with it and some old oil/grease stains, tried to get it to soak in to the patio with a bit of water (not enough to wash it away) and scrubbed with a stiff brush, then jet washed off |
04-18-2024, 12:40 PM | #16 |
Rep 416
Thanks all, I realized that I have clean slabs under the shed that will be good for a swap.
As well as found out that there is no way to remove it completely but only to decrease its visibility slightly. And yes, its a really intense stain from a differential box.
