09-26-2016, 03:58 AM | #1 |
Rep 122
HELP!!! Oil Pan!
Hello everyone!
So today I did my brake flush and after completion decided to do a test drive. So I took it for a spin and when I got back noticed oil under the car. I ended up taking belly pan and oil pan is full of oil. Looks like it needs to be replaced. My question is does anybody have a DIY on how to take it down, because it seems complicated due to 4 bolts that hold the flywheel and axle support. Please help any information will be helpful! |
09-27-2016, 04:55 AM | #2 |
Rep 12,736
It's a big job. What how is it damaged? Looks like a typo or autocorrect didn't spell out what you were trying to say.
09-27-2016, 05:23 AM | #3 |
Rep 10,677
First few steps of rod bearing DIY. Search and you will find out what you need. It will take you a day or most of one but its doable.
09-27-2016, 07:51 AM | #4 |
424 ASP
68
Rep 242
Drives: '11 AW E92 M3 ZCP
Aside from a typical set of sockets and wrenches, you need to posses a couple shop tools...
- Jack, Jack Stands, Engine support bar (Harbor Freight). I have a lift in my garage and did my rod bearings but the process is much the same. It wasn't bad at all. Take your time. One bolt at at a time it all comes apart and goes back together. If you do in fact do this, absolutely do your rod bearing at the same time FOR SURE. |
09-27-2016, 02:04 PM | #5 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
have you checked if it's the oil measurement sensor in the middle? there is an o-ring there that can leak. the whole sensor is less than $300 or some have replace the oring. i'd start there unless you've already identified the damaged area.
09-27-2016, 03:03 PM | #6 |
Rep 122
I don't have enough tools to do a complete lift and get a good look at it. I jacked left side got underneath the car and took off the belly pan along with metal plate underneath the engine. That metal plate was full of oil. I got under the car and noticed lots of oil around oil pan. I couldn't detect the leaking point for sure because steering rack and axle support bar is on the way but from what I saw it looks like its rather a cracked oil pan or leaking oil pan gasket.
09-27-2016, 03:05 PM | #7 |
Rep 122
09-27-2016, 03:08 PM | #8 | |
Rep 122
09-28-2016, 09:38 PM | #9 |
Retired Curmudgeon
2997
Rep 4,069
Any chance the leak is really just the result of a careless oil change(s)? I'd hate for you to have to do a ton of work when it was something else.
Whenever I've had a leak, the first thing I do is clean everything up and then keep a close watch to see exactly where the leak is coming from.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
09-29-2016, 10:42 PM | #11 | |
Rep 323
