10-02-2023, 05:55 PM | #1 |
Rep 2,650
2018 340i xDrive BM3 MM S2+ dyno
Brought my car to my local dyno to see what it makes on 91!
433AWHP/521AWTQ Mods are: BM3 Multimap stage 2+ 91 OTS BM3 flexfuel kit CTS turbo catless DP TU HPFP
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
10-05-2023, 07:38 AM | #6 |
Rep 2,650
10-05-2023, 08:00 AM | #7 |
Rep 118
Thanks. The only "bad" thing I can see is a throttle closure and some timing corrections between around 3,800 until 4,800 rpm. Seems like a little bit too much boost in the beginning. But except for that pretty nice values considerung 91 oct only.
10-05-2023, 12:34 PM | #8 | |
Rep 2,650
What's important is the results after 5k rpm. Here's a multiple gear pull example. https://bootmod3.net/log?id=64ddf0feae729b43b3899caf A few corrections but nothing too serious, mostly heat related and 91. But you're still seeing positive timing so it's not a bad map to run.
Tags |
bm3, bmw, ots |
