2010 2011 BMW 5 Series Forum F10
2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 550i drivetrain malfunction
      02-05-2024, 02:09 PM   #1
kadennm
Drives: 2012 bmw 550i
Hello I am new to the forums and was hoping to find help here. I have a 2012 F10 550i that has around 76k miles. Recently I got a drivetrain malfunction code that popped up on my screen. My check engine light came on and won’t disappear unless I erase the codes. After scanning it into the obd2 port the code “manufacturer control” pops up. After I erase It, it disappears for a few hours/ days and then comes back on again. i recently did an oil change and replaced my spark plugs and ignition coils. I was thinking it could it be a faulty sensor or a transmission leak. Anything helps guys thanks.
      02-07-2024, 11:48 PM   #2
3002 tii
3002 tii's Avatar
2304
Drives: Z4 M, X5, GX460
What’s the actual code? P0xxx?
Follow for latest mods
      02-08-2024, 11:39 AM   #3
kadennm
P139A
      02-08-2024, 05:33 PM   #4
3002 tii
3002 tii's Avatar
2304
Originally Posted by kadennm View Post
P139A
That’s your rear o2 sensor.
      02-08-2024, 07:09 PM   #5
kadennm
Just ordered one, thanks for the help. Hopefully this fixes the issue
      02-16-2024, 09:13 AM   #6
Dlucke17
Drives: 550i, X5, 240sx
kadennm once you install, please update this thread with results. I'm fighting through the same Malfunction.
      04-10-2024, 04:51 PM   #7
kadennm
Apologies it took awhile. Recently replaced both upstream and downstream o2 sensors and noticed somewhat of a difference. The drivetrain malfunction disappeared but I still experience a rough idle sometimes. Thinking it could be fuel injectors or something similar. Hope this helps.
      04-13-2024, 01:49 PM   #8
Hornet-01
Hornet-01's Avatar
Russia
164
Drives: BMW 550 xdrive
2011 550ix  [9.50]
check MAF, and what is the air flow on the engine idling. And what correction lambda long correction and fast correction. Also check parameters injectors, but i think this MAF
Maybe you needs to change MAF sensors.
      04-13-2024, 01:51 PM   #9
Hornet-01
Hornet-01's Avatar
Russia
164
2011 550ix  [9.50]
use Veachical logger to watch parameters
5post
