F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Knocking noise when going over bumps or uneven roads
ARMA SPEED
      04-16-2024, 07:05 PM   #1
mclovin69x
Drives: 2018 BMW 440i GC
I’ve been hearing this clunk or knock sound when going over uneven road surfaces or bumps.
I first noticed this after switching out my shocks and struts to new ones. In this process, I remove the tie rod end from the wheel hub to make things easier. I know it’s not from either the shocks or the struts because I have done this before without removing the tie rods and have not had this issue.
Today I jacked up the car and re-torqued the tie rods to the wheel hub without preload and also tightened the steering rack bushing because I figured the noise might’ve been coming from there.
Made the noise a lot worse. I am almost certain it’s coming from the tightening of the steering rack bushing. If I loosen it, the sound is much worse. if I tighten it, the sound gets slightly better, but the steering gets so stiff that it doesn’t return to center after completing a turn.
What should my next steps be to fix this issue?
https://youtube.com/shorts/_fdu4-T88...UGCJoec-iq3mGD
      04-17-2024, 09:54 AM   #2
samspiderman3125
samspiderman3125's Avatar
46
Drives: 2017 440i gran coupe
check your sway bar end links, make sure theyre tight, jack the car up and have a friend turn the car so you can hear it down lower and isolate it
      04-17-2024, 10:13 AM   #3
mclovin69x
Already done. Sway bar end links are tight as can be.
There is no noise when turning the wheel only when going over bumps. I’m thinking it might be the inner tie rod ends that are loose or a blown ball joint on them
      04-17-2024, 11:58 AM   #4
mhowanic
Drives: 2017 BMW 440i GramCoupe
Check the struts and how far they are through the knuckle. I replaced mine and one slid in much further than the other and I started getting a knocking noise like that over bumps. The bottom of the strut was hitting whatever is below it. I measured the old struts and reset where they sit in the knuckle and the noise went away.
      04-17-2024, 12:00 PM   #5
mclovin69x
Hmm good advise thank you. I will jack up the car later today and see if I find anything.
I did suspect that and compared and they were equal on both sides but you can never be too sure
      04-17-2024, 02:21 PM   #6
mhowanic
They can be even on both sides but slightly too far into the knuckle. I’ve read some guys say that they put the strut in after removing the spreading tool.
In my case for whatever reason one slid too far in and the other was perfect. So I’m not sure what the variance is that causes that. But it certainly made a knocking sound. You can look at the bottom of the strut and see if there is any sign it was hitting something.
      04-25-2024, 03:28 PM   #7
mclovin69x
Got it. Thanks
Turns out a sway bar end link was loose. Tightened it up and the noise is gone.
Burnout27.00
f30post
