03-04-2021, 11:54 AM | #1 |
Rep 5
No Audio - Harman Kardon
Hello
I have a strange issue with my 420d GC. When I got in it today, there was no audio. No chimes for parking sensors, nothing. The volume control does not even show on the screen when you try to adjust it - an its not on mute Strangely, it has lost the date and time too, but only on the iDrive, the dash still has the correct date and time. I have not plugged anything new in or changed anything so not sure why it would suddenly stop. I've seen a few other people post on here buy have not actually seen a resolution Any help or ideas would be appreciated. thanks |
03-04-2021, 12:19 PM | #2 |
Rep 1,574
Randon thought: How old is the battery? Have it tested. When these batteries start to go, we often get a myrid of strange electrical issues.
03-04-2021, 12:50 PM | #3 |
Rep 5
03-04-2021, 12:53 PM | #4 |
Rep 1,980
Drives: 2020 G20 320i M Sport
You have an open circuit somewhere in the Most bus and the HK amp, head unit and instrument cluster all communicate through this fibre optic network so possible that one of these components had failed (likely the HK amp).
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
03-04-2021, 01:01 PM | #5 |
Rep 5
Thanks for the heads up. Do you know of a way I can check to see what component it is? Is it likely to be a fuse?
03-04-2021, 02:25 PM | #6 |
Rep 16,145
You need an ODB diagnostic tool to read error codes that may pinpoint the fault.
steve@codemybimmer667.50 |
03-05-2021, 07:19 AM | #7 | |
Rep 1,980
If you terminate the HK amp and you notice that the warning tones, service and time comes back on the head unit then you know the Amp is causing the problem. https://www.ebay.co.uk/itm/2x-MOST-F...75.c101224.m-1
03-05-2021, 07:20 AM | #8 | |
Rep 1,980
If you terminate the most connection on the HK amp and you notice that the warning tones, service and time comes back on the head unit then you know the Amp is causing the problem. Search " Most loop terminator female " on eBay and you should be able to find these for under $10.
03-05-2021, 07:50 AM | #9 |
Rep 5
Thanks all for the help!
I managed to fix it and thought I’d share the fix that worked for me rather than going silent After pulling all the fuses relating to the audio and checking them I found they were all still good. I next turned my attention to the amp, I checked the connectors on it and when pushing the fibre connector I heard a click and then all the audio came back! It looks like the connector wasn’t seated properly - phew! |
03-05-2021, 08:13 AM | #10 | |
Rep 1,980
Yep, that would do it as well since the connection was loose causing the fibre loop to be disrupted.
Tags |
audio, harmam kardon, idrive |
