      03-18-2024, 12:18 AM   #1
Snoball M3
Snoball M3's Avatar
Drives: 2008 328i MB Sedan/11.5 ZCP M3
BM  [0.00]
O2 sensors?
Been getting this code, replaced all 4 o2 senors(Bosch FCP Euro), had an exhaust leak (replaced donut gaskets), replaced battery (Duralast AGM) and cleared codes. Did find Bank 1 post cat senor connection with a corroded pin due to old sensor missing green gasket (pics included), water was trapped between the connections when replaced but was able remove most of the corrosion. Drove 100 miles to see if codes would clear after but keeps returning with these codes:
Is there a fuse for all 4 sensors? If so where is it located??
2008 328I MB M-Sport E90
2011.5 E90 AW ZCP M3
1965 C-10 SWB (bagged)
      03-18-2024, 02:43 AM   #2
Theodore
Theodore's Avatar
Drives: 2011.5 E92 M3
In the past I experienced a similar situation and replacing the DCT wiring harness (which includes the wiring for the 2 post CAT O2 sensors) along with the replacing my leaking DCT mechatronics harness o-ring removed the errors for all 4 O2 sensors simultaneously I was experiencing.
What I Wish I Knew When I First Bought My E9X M3 Can Be Found Here
E9X M3 Exact Original Equipment (OE) Equivalent Parts Can Be Found Here
E9X M3 Common Torque Specs Can Be Found Here
E9X M3 "Factory" Tools Can Be Found Here
      03-18-2024, 11:21 AM   #3
Snoball M3
Snoball M3's Avatar
BM  [0.00]
Originally Posted by Theodore View Post
In the past I experienced a similar situation and replacing the DCT wiring harness (which includes the wiring for all 4 O2 sensors) along with the replacing my leaking DCT mechatronics harness o-ring removed the errors for all 4 O2 sensors simultaneously I was experiencing.
Did you DIY this yourself?? Sounds like a major pita....Did the codes immediately clear after?
      03-18-2024, 11:59 AM   #4
Theodore
Theodore's Avatar
Yes to both, you can follow this DIY DCT mechatronics harness o-ring and the only step not shown is to disconnect the final connection point of the DCT/O2 sensor wiring harness from the relay box under the hood on the passenger side of the car which is self explanatory.
      03-25-2024, 02:53 AM   #5
Mr.Zisky
Mr.Zisky's Avatar
17
Drives: 2013 BMW E93 M3
That wiring harness has only 2 connectors for o2 sensors. As far as I remember pre-cat o2 sensors connectors are part of main engine harness and only 2 post-cat sensors are part of DCT harness, no?
      03-25-2024, 09:24 AM   #6
Theodore
Theodore's Avatar
You are correct, I edited my original post.
