11-17-2019, 09:16 PM | #3 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
BCS catted downpipe and OTS BM3 E30 tune.
Made 307whp on this dyno Stock |
11-18-2019, 06:24 AM | #4 |
Cheapskate
4464
Rep 4,995
Stock vs. Stage 1 93
BMWILUVU814.00 SupremeF3455.00 |
11-18-2019, 06:37 AM | #5 |
Rep 1,023
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
Tunes: Self Made Tunes - MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=...33-34-35-36-37 |
11-18-2019, 07:40 AM | #6 |
Cheapskate
4464
Rep 4,995
Dynojets can only report horsepower at the wheels.
11-18-2019, 07:49 AM | #7 |
Rep 1,597
11-18-2019, 08:56 AM | #8 | |
Cheapskate
4464
Rep 4,995
RWD Manual transmission 330mm rear brakes vs the 345 MSport/MPerformance brakes Forged 18" wheels (19lbs each) Only 10k miles on the engine At the end of the day, there are also a lot of factors that can play into dyno readings. Temperature, DA, Humidity, fuel quality, etc. can cause your hp readings to vary from day to day. I'd expect a big difference because I'm in Ohio and he's down in Florida. Even just on my dyno runs, I measured 385, 396, then 398. That's a 14hp spread across (3) runs within 15 minutes of each other. So you can't really compare two different dyno readings. That's why I did stock, and then tuned to compare the gains. That's more important than the actual numbers. |
11-18-2019, 10:00 AM | #9 |
Rep 1,023
So your car stock with 15% loss has around 390 at the crank!!
You think BMW are underrating their engines or Dynojets are overrating or both ?
11-18-2019, 10:04 AM | #10 |
Rep 24
I have seen a lot of data supporting BMW underrating their HP. My old F80 M3 was almost putting down to the wheels what it was rated at crank stock.
disintegrator66436.50 |
11-18-2019, 10:16 AM | #11 |
Rep 1,023
Yes BMW underrating their engine power has been floating around for quite some time but by 70 HP is quite too much.
11-18-2019, 10:57 AM | #13 |
Rep 103
One thing to look at is if a dynojet is shown in STD or SAE. You can only really compare SAE to SAE for a relatively close comparison. Its a correction factor that portrays similar numbers across different dynojets (corrects for weather, elevation, etc. to give a consistent number across different regions). STD numbers are almost always significantly higher. If you look around the site you'll notice most stock b58 cars do 300-310whp SAE and 330-340whp STD. On my previous car, the dyno operator gave me both and STD was around 25 hp and tq higher across the board.
11-18-2019, 11:18 AM | #14 |
Rep 191,521
+1
Check out our current sale by clicking on this link!
https://x-ph.com/sale/ Phone number 702-494-9435 |
11-18-2019, 12:18 PM | #15 | |
Cheapskate
4464
Rep 4,995
2. I don't think I have 15% drivetrain loss. As I said, my car with lighter wheels, and the least restrictive drivetrain option could make the same engine power as another 340i with heavy 19" wheels and auto trans and we'll make different power at the wheels. Another example - my diff ratio is higher than autos, so my torque will be higher and therefore horsepower. That's why i never claim any bhp rating. A modern engine with coated cylinders, 0w20 oil, and all the other efficiency improvements don't have the same drivetrain losses as cars from the 90s just because they're both rwd. You can't compare dyno figures, and you can't slap a percentage loss on it. All my video confirms is I had up to 18% gain by flashing Stage 1. |
11-18-2019, 12:22 PM | #16 | |
Rep 1,363
http://forum.cog-online.org/concours...hy-it-matters/
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
BMWILUVU814.00 |
11-18-2019, 12:25 PM | #17 |
Rep 44
Yeah that’s why I asked, I haven’t yet put my 340i xDrive on a dyno, But was curious what I’m making to the wheels?
(Stage 2 93 - BM3, Vrsf catless downpipe) (NO mppsk 320hp stock) |
11-18-2019, 12:30 PM | #18 | |
Cheapskate
4464
Rep 4,995
When people ask how much power I'm making, I say at least 321hp it's just not as important to me. Just go enjoy it and pull on some unsuspecting N54s. |
Dheeth-G80226.50 |
11-18-2019, 02:42 PM | #20 | |
Rep 24
11-18-2019, 05:56 PM | #21 | |
Rep 176
I remember actually being scared in my old car sometimes from how violent it was. I even beat a new turbo 911 on the highway with it (not the Turbo, but the base 911 which also has twin turbos now), maybe my old car was some kind of factory freak I never quiiiite get those feelings in my B58, even though I can tell it's fast. I don't think it's a case of how the torque comes on more linearly either. Kinda bummed about it honestly but I have yet to bring this up to the PTF guys since I haven't had time to go grab logs. Hopefully they can somehow squeeze some more power out of it. |
11-18-2019, 11:06 PM | #22 | |
Rep 1,326
Also, afaik, the A8 is no longer sold or supported by Active Autowerke any longer in replacement of their flash tune, which is inferior to other tunes such as BM3, MHD, Mission, etc. IMO.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
