04-22-2024, 11:20 PM | #1 |
Rep 4
Missing Key Fob Button?
Hello,
Just purchased a used X7 and received two key fobs, one in great condition and the other in not so great condition. The second key fob is missing the lock button but the functions still all work. Is there a way to purchase the missing button and clip it back on or will I just need to purchase a generic/used key fob shell? If it is the latter, does anyone have any recommendations on aftermarket shell? |
04-23-2024, 08:01 AM | #2 |
Rep 243
Why not buy a used fob and transpose the buttons to your current? Does it work that way? It might not. I haven’t taken the fob apart.
key fob used If that doesn’t work, dealer can program it but likely will be expensive. |
04-23-2024, 10:36 AM | #4 | |
Rep 7,577
Perhaps the OP can attempt to remove the IC board and implant it into a compatible new or used remote fob. But they will need to use the IC board that has the transponder that is written with the same encryption that matches the same 128-bit encryption on their CAS/FEM/BDC/DME modules.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-23-2024 at 10:42 AM.. |
04-23-2024, 10:40 AM | #5 | |
Rep 243
04-23-2024, 03:53 PM | #6 |
Rep 7,577
I honestly don't know. But since the one button is missing on the remote pictured above, I'd fiddle with it to see if the other buttons can be removed and replaced without any damage. That could be an indicator of any ease of buying a remote online and popping the buttons on/off.
Good luck...keep us posted with your decision, especially if the buttons can be popped off/on with no damage.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
04-23-2024, 09:16 PM | #8 |
Rep 1,104
Carve out a piece of wood or plastic that fits and functions as the missing button. Then buy a soft leather fob cover that will mask the crafted button and all the damage the dog did. You'll be the only one that knows.
04-24-2024, 09:52 PM | #9 | |
Rep 4
I |
04-24-2024, 10:18 PM | #10 | |
Rep 4
04-24-2024, 11:25 PM | #11 |
Rep 243
Key blade should be same length. Obviously cut differently but should t be an issue if you get a similar key profile. These are manufactured in large scale so having various sizes is inefficient and very unlikely.
04-26-2024, 06:02 PM | #12 |
Rep 7,577
Ditto, the metal key has its own 11 digit BMW part number…so you can run that number through one of the online part database sites to see which remotes that it works with.
Obviously it needs to be the same design…but some of the remotes have different exterior looks depending on if you have the sport pkg or some other package. But again, the metal key blade is the same and fits all of the remotes.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-26-2024 at 06:18 PM.. |
04-29-2024, 11:20 PM | #13 |
Rep 4
Just swapped the keys, a lot easier than I expected it to be.
For anyone trying to do this, make sure you buy another fob with the correct part number and just be gentle with a flathead/plastic pry tool and have the correct size torx bit. Turns out someone tried to swap the buttons originally in my key and snapped all the nubs on the buttons but couldn't get them out so during replacement I had a bunch of plastic fall out of my key, swapped the buttons with the new ones and everything works great. |
25X740i6.00 bradythedog12127.00 |
05-02-2024, 03:27 PM | #14 |
Rep 7,577
Great...good to read that you got things sorted. Your follow up post is much appreciated.
