BMW
X7 and XM
forum
BMW X7 (G07) Forums General BMW X7 Forum BMW code names
      04-24-2024, 01:39 PM   #1
lloyd99
lloyd99
100
Drives: 2021 X7 M50i
2021 X7 M50i  [9.00]
BMW code names
Hi all. I joined this forum about 18 months ago, alongside the purchase of my first BMW - a CPO 2021 X7 M50i. I have learned a lot from reading the posts. As a BMW newbie, I am sometimes confused by the E, F, G codes that are used when referring to the various vehicle models, as well as the N and S codes used when referring to various engines. I decided to do a little google searching to learn more. From my readings, I believe the following is correct. Can you confirm?
- Each BMW historically carried an E project number – standing for Entwicklung, or development. The numbers rose progressively up to triple digits, at which point F numbers took over, and then G numbers eventually took over.
- E53 = 1st-gen X5, 2000-2006
- E70 = 2nd-gen X5, 2007-2013
- F15 = 3rd-gen X5 2014-2017
- F85 = X5 M, 2015-
- G05 = 4th-gen X5, 2018-present
- G07 = X7, 2019-present
- G09 = XM, 2022-present
- BMW B58 = turbocharged straight-six engine, which began production in 2015. Used in X5 40i and X7 40i.
- BMW N63 = twin-turbocharged petrol V8 engine, in production from 2008-present. 2020-2023; G05 X5 M50i, 2020-2022; G07 X7 M50i
- BMW S63 = BMW M version of the N63, which debuted in the BMW X6 M and was used in the BMW M5 models from 2011 to 2023.
- BMW S68 = twin-turbocharged V8 engine, first use was in the 2022 revised BMW X7 as the M60i.
Sources:
- https://www.carmagazine.co.uk/car-ne...mes-explained/
- https://en.wikipedia.org/wiki/BMW_X5
- https://en.wikipedia.org/wiki/BMW_X7
- https://en.wikipedia.org/wiki/BMW_XM
- https://en.wikipedia.org/wiki/BMW_N63
- https://en.wikipedia.org/wiki/BMW_B58
- https://en.wikipedia.org/wiki/BMW_S68
newb21.00
      04-24-2024, 04:22 PM   #2
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
Pretty much correct. The f95 is the g05 X5 version of the X5M.
F85 X5M - F15 X5
F95 X5M - G05 X5
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      04-24-2024, 07:47 PM   #3
lloyd99
lloyd99
100
2021 X7 M50i  [9.00]
F85 X5M - F15 X5
F95 X5M - G05 X5
Got it, thanks very much.
      04-24-2024, 08:06 PM   #4
Bimmer303
Drives: X5, maybe X7 Soon
That’s helpful! Noob here too. Have an F15. Trying to find a good G07 here soon. Thanks!
      04-27-2024, 09:08 AM   #5
exokiss
exokiss's Avatar
Drives: 2020 BMW X7
2020 BMW X7  [0.00]
What are the 2024 X7 LCI engine codes, please? Thanks.
      04-27-2024, 06:38 PM   #6
Qsilver7
Qsilver7's Avatar
2024 X7:
  • B58 - X7 xDrive40i is powered by a 375-hp turbocharged inline-six-cylinder
  • S68 - M60i has a twin-turbo 4.4-liter V-8 that makes 523 horses
  • N63 - Alpina XB7 has a specially tuned version of that V-8, which develops 630 horsepower
Pre LCI and LCI X7 models:
      04-27-2024, 07:25 PM   #7
newb
newb's Avatar
21
Drives: none yet
Man, I appreciate this post so much. Thanks a million
      04-27-2024, 08:59 PM   #8
M_Bimmer
M_Bimmer's Avatar
612
Drives: G12 B7, G07 XB7, F02 B7, 991.1
2024 X7:
I'm petty sure the LCI G07 XB7 uses the S68 too....the plumbing on my engine sure looks like the S68...rated at 631 ponies.
      04-27-2024, 09:07 PM   #9
M_Bimmer
M_Bimmer's Avatar
612
lloyd99 , don't forget that most BMW chassis and drive trains undergo a mid-cycle change called LCI....but, not all BMWs have an LCI variante.
You can also look up part numbers by chassis and engine code, along side LCI, at realOEM.com.
      04-27-2024, 09:30 PM   #10
Qsilver7
Qsilver7's Avatar
…thanks for the additional info about the LCI XB7…you’re correct, it got a tweaked S68 that upped the ponies as you stated:
The XB7 continues to use a tuned version of the twin-turbocharged 4.4-liter V-8 found in the X7 M60i, but while the pre-facelift XB7 made 613 horsepower, the new version boosts that to 631 ponies. Torque stays the same at 590 pound-feet—a 37 pound-foot advantage over the M60i—and BMW says the torque peak arrives 200 rpm earlier, at 1800 rpm, and lasts until 5600 rpm.
xbimmers
