04-20-2021, 02:46 PM | #1 |
Rep 16
EDC delete
Hi!
I'm trying to code out my EDC module. Coilovers have been installed. I've found the following recipe: 1) Unplug EDC module 2) Remove $233 from VO 3) in KOMBI, set EDCK_ALIVE_ZAEHLER and EDCK_ID_MONITOR to "nicht_aktiv" 4) in CAPPL, set EDC to "nicht_aktiv" (later CIC cars set EDC_CIC to "night_aktiv") 5) Clear faults using INPA But this only gets rid of the error message in the kombi and CIC. When scanning the car in INPA there is a error saying the EDC module not present or working. It also does not make any sense to me to remove $233 from VO but not code any modules afterwards. Do anyone know which modules that are affiliated to the EDC module and should be coded after altering the VO ? |
04-20-2021, 03:06 PM | #3 |
Rep 16
Thanks for the reply tdott.
The VO is changed and FA_WRITE to both CAS and FRM. So the VO is updated. But then it is necessary to update the correct modules with the new VO. And this is where I am a little stuck - which modules do I now need to run SG_CODIEREN on ? Are the CAS and M3DSC modules related to the EDC and needs to be coded ? Any other modules ? Which modules need to be told that there no longer is any EDC module in the car. |
04-20-2021, 03:25 PM | #4 | |
Naval Aviator
666
Rep 694
Performance Mods: Alpine Stage II; SuperSprint config: non-resonated front+X-pipes+F1s; cat-less; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK |
04-20-2021, 10:53 PM | #5 |
Rep 16
04-25-2021, 12:09 PM | #6 |
Rep 16
Did some further testing to try getting rid of the CDB7 error popping up when scanning the car with INPA.
I have unplugged the blue connector from the EDC module and default coded CIC, KOMBI, CAS and M3DSC with updated VO where $233 is removed. Default coding the CIC changes EDC_CIC to "nicht_aktiv" and default coding KOMBI changes EDCK_ALIVE_ZAEHLER and EDCK_ID_MONITOR to "nicht_aktiv". Default coding cas and M3DSC changes no values. When driving the car everything looks and behaves like normal, but when scanning the car error CDB7 shows up under DDE/DME module in INPA. Do everyone who has coded out EDC have a CDB7 error when scanning car ? Or am I missing something ? |
08-03-2023, 11:01 AM | #7 | |
Rep 221
Almost all other places where this "EDC coding delete" is discussed, the focus is on removing the white connector. But often it's not specified. In one post, aside from yours, I saw also that they had additionally also removed the blue connector. Did you eventually fix your issues and what was the resolution? And what did you do with the connectors?
2011 E92 M3 mods: Alex tune, mod'd X-pipe, MPEv2, MS intake stage 2, ESS power pulley, Monoball bearings, SSFBs, PFv3 rotors, MFactory DSv3, RE SSK, Voltphreaks Li batt.
For sale: E92M3: BW Race muffler, front thrust arms, stock muffler, 19" Vorsteiner VFF103 rims Z4MC: KW V3 coilovers (rears) |
