01-03-2022, 08:25 PM | #1 |
Rep 191
Coding CD Changer to CCC
I'm adding a mr12volt P600 and I am trying to code the cd changer to my 2008 M3 with CCC. I'm using Bimmercode and selected 3010 CCC_ECUS under the head unit expert mode. I was able to change the selection to active, the coded it. This did not work and I got a coding error. When I go back into 3010 CCC_ECUS, it still shows as active.
As a test I tried adding the weather band and I got the same coding error. However the weather band was actually added to the radio. Is there more coding that needs to be done to add the cd changer?
08 E92 M 6spd Gearbox Space Gray on Fox Red - Redline MTL - Redline 75W140 - 50% Llumar Film - OEM Exhaust Mod - Black Grilles & Gills - Dinan Software - Dinan Springs - F10 M5 Knob - Apex 19" ARC-8
06-14-2022, 07:17 AM | #4 |
Rep 2,029
Drives: '05 M3 6MT
Did you ever figure out a solution here? Thinking of grabbing the mr12volt for my E91 and already have Bimmercode from owning an M340i for a short while.
'05 BMW M3 6MT (Weekend car) Need to stock up on some detailing products or spiff up your garage, then use my Obsessed Garage link! |
04-14-2023, 01:53 AM | #5 |
Rep 2
You have to change it to mp3_cdc
lakehoustonnative37.00 |
07-06-2023, 07:11 PM | #7 |
Rep 3,015
Sometimes the bimmercode tool can't do what you want it to do, so its best to have someone code it with a laptop.
INSTAGRAM: GORDON.M3
