04-02-2008, 06:51 PM | #1 |
Fanatic
99
Rep 175
Key Fob Failure
After I got my BMW back from the dealership and drove it home, I got out of the car and pressed the lock button on the fob and it didn't respond.
I then tried unlock/trunk as well and nothing.. I grabbed my spare and tried it out, and it worked perfectly.. My question is, should I make the dealership replace the fob and how much is a new one?? (I plan on making them replace it) -Nathan
04-02-2008, 06:51 PM | #2 |
General
384
Rep 21,747
Drives: E92 335i TiAg/E46 323i TiAg
Maybe it lost it's charge. You have to once in awhile insert it in to maintain charge.
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo |
04-02-2008, 11:05 PM | #3 | |
Fanatic
99
Rep 175
Any other possibilities?? -Nathan
04-02-2008, 11:15 PM | #5 |
Rep 1,035
I'd guess your battery went bad then. The batteries are replaceable. A new key costs around $200-225 programmed.
04-02-2008, 11:57 PM | #7 |
Rep 1,169
Drives: 67 GT500,69 Boss 429, 335i
Check your battery...
-Mat
Tuned E92 335, Riss Racing downpipes! And hopefully over 400RWHP!! |
04-03-2008, 01:55 AM | #8 |
Fanatic
99
Rep 175
On top of that they had my car waxed without asking me and left several spots unbuffed, just waiting to be caked in.. -___- Looked/Looks terrible..
If it's the battery, then I guess I will replace it myself.. If somehow it is messed up, I will make them fix it/give me a new one. EDIT: After reading some sites, I've learned that my battery should never need replacement and it should charge automatically.. -Nathan
04-03-2008, 02:03 AM | #9 |
Rep 1,035
No, the battery can go bad and it does need to be replaced from time to time. It recharges when it's in the keyhole when you drive. The owner's manual even says you replace the battery from time to time.
04-03-2008, 08:15 AM | #10 |
Commander in Chief
37
Rep 1,034
You may simply have a bad remote. It happened to me while I was away on a trip. I had to use the metal key to unlock my doors, but when when I would insert the keyfob into the slot, the car would start normally.
BMW replaced the remote portion of the keyfob under warranty, otherwise it would cost about $250. In order to get a new one, you have to verify your identity and apparently have the replacement sent from Germany.
2008 BMW 535i Space Gray, Black Leather, Dark Bamboo Trim| Sport Automatic with Paddles | Sport Package
2008 BMW M5 (gone, but not forgotten) Space Gray, Silverstone Merino Leather, Madeira Walnut Wood Trim | 7speed SMG | All options Mods: Corsa Exhaust | RPI Ram Air Intake | H&R Sport Springs | Rogue Engineering 12mm spacers |
04-08-2008, 10:50 PM | #11 |
Fanatic
99
Rep 175
Apparently it became 'un-synced' from the bmw..
Made a trip to the dealership, he fooled around with it in the ignition and door for a little while and it was as good as new. -Nathan
04-08-2008, 11:26 PM | #12 |
Rep 2,484
i say make them replace it
08 E92 AW M3 | HRE P40 19" | APE Air Filter | BMW Performance Grills | White Side Gills | CF Mirror Covers | BMW Performance Pedals | F1 Pinnacle Tint | V1 Hardwire | Dinan Performance Software | Gintani Exhaust | H&R Sports Springs | RPI Scoops | BMW CF Spoiler | Challenge Diffuser | Lux H8 V3 | LCI Tail Lights | |
