04-04-2024, 12:37 PM | #1 |
Rep 48
Possible HPFP cooked ??
Today i was driving my car and it shut off while idling at a red light . car wont start only cranks. Had about 50 miles left in gas tank . i am guilty of driving the car low on gas plenty of times and ran out of gas about 3 times total . LPFP is showin 84 psi in log & HPFP IS SHOWING 80-85 Psi when cranking . checked the codes through bm3 and got these codes. im assuming its the hpfp but i want to see if anybody else has had this issue and if they solved it or if anybody has thoughts of what it can be . thanks
car also had stalling issue when i drove for long periods of time ( 1-2+ hours ) it would start back up ( only happened about 3-4 times since 2 years ago ) hasnt happened for about 6 months BMW specialized shop is charging $520 for labor to replace hpfp . how hard is this to do myself and what tools would i need ? & is there a way to do it without removing manifold 21a023- combustion engine false start 11b401- high fuel pressure during or after he injection is enabled ( 2nd set of environmental conditions after a time delay - pressure too low 11a401- high fuel pressure when injected is enabled : pressure too low |
04-04-2024, 12:57 PM | #2 |
Rep 4,174
You can have my old one for free if you need it.
Mods: Yes.
Skrrtt33515.00 Eschmacher334.50 |
04-04-2024, 01:08 PM | #3 |
Rep 48
04-04-2024, 01:14 PM | #5 |
Rep 48
04-10-2024, 05:24 PM | #9 |
Rep 48
AmuroRay2316.50 Eschmacher334.50 |
04-11-2024, 01:18 PM | #12 |
Rep 48
Looked normal to me i compared them side to side and were the same . The bad hpfp just had alot of debris & was dirty . i did run out of gas about 4 times idk if that has anything to do with it
04-11-2024, 01:27 PM | #13 |
Rep 7,624
