03-01-2024, 11:30 AM | #1 |
Rep 520
New Product - Evolve x Bilstein B6 Damptronic EDC Dampers
Introducing the Evolve x Bilstein B6 EDC Damptronic Damper for E9x M3! We have developed these dampers in conjunction with Bilstein UK over a period of years. As good as the original Bilstein dampers were, we wanted to tailor them for use with lowering springs and MSS Height Adjustable Springs. We worked with Bilstein to change the valving to make the Comfort setting even more compliant and the Sport + setting slightly stiffer giving more range of damping given by the electronic modes in the EDC equipped E90, E92 and E93 M3. Not only that but a common complaint for all B6/B8 dampers is that they lift the front slightly. This wasn't something we wanted so with a lot of back and forth with Bilstein we have developed a slightly shorter damper body that solves this issue. (some lift may be evident when brand new comparing to a used damper due to the nature of how Bilstein uses a gas pressurised damper) These are now in stock on the shelf ready to ship worldwide! - https://www.evolveautomotive.co.uk/p...v&_ss=e&_v=1.0 Product overview, install and driving impressions video: Installed photos paired with MSS HAS kit, set to full low on the front Independent video by M539 Restorations paired with standard springs We can't wait to hear the feedback from customers and see installed photos with various spring and wheel setups!
03-02-2024, 12:55 PM | #5 |
Rep 156
I’ve read in the comment section on your most recent YouTube post above - that one needs to reset the run time memory on the EDC system after installing the new dampers.
Truth? Last edited by Racer-X; 03-02-2024 at 01:08 PM.. |
03-02-2024, 03:18 PM | #6 | |
Rep 475
Drives: 2009 E93 M3 DCT
03-02-2024, 05:52 PM | #7 | |
Rep 156
Thanks I guess - perhaps evolve can answer the back and forth of that thread.
And if the new shocks I got for evolve require a reset - what do I tell my dealership or speed shop or Me the shady tree mechanic to get this done. Quote:
03-02-2024, 06:08 PM | #8 |
Rep 475
Did you read the document? It clearly states from BMW that a reset must be done after changing out the EDC shocks. This has nothing to do with evolve and everything to do with BMW
03-03-2024, 07:48 AM | #9 |
Rep 156
Yes I did - thanks for implying I didn’t. It has lots of back and forth and contradicting information at times. (I read it before posting and again if you must know Brandoch)
Did you read all of my post of two sentences? If you did, please answer me what I tell my dealership or speed shop after I do the work… or allow evolve too. The post you keep pointing to, never clears that up. Heck one person in that thread has a buddy that is a tech at BMW, who was unfamiliar with e92s needing this in the first place. What do you tell that tech? Since evolve never addresses this in any of their videos over the years - Ill reask them the question. Perhaps they have a solution or a thought outside your pointing to threads. |
DjMarkOne105.00 |
03-03-2024, 09:13 AM | #10 |
Rep 475
"After a replacement, the running time memory for the front or rear axle must be reset with the BMW diagnostic equipment"
Directly from the BMW training manual |
03-03-2024, 10:56 AM | #11 | ||
Rep 5,595
So the above is correct - you need to make sure the edc damper running time reset procedure is executed on both the front and rear new edc dampers after they’ve been plugged into the car. If it is not done, your new Evolve/Bilstein dampers will have their damping force output biased higher based on the age of your old edc dampers. |
03-03-2024, 01:21 PM | #12 |
Rep 5,595
So to address the raised ride height with the B6 dampers, you lowered where the lower spring seat mounts on the damper, or shortened the length of the damper body (which does the same thing), relative to the knuckle mount on the damper? The only other viable option would be to reduce the internal pressure in the monotube B6 damper which I’d be surprised if Bilstein would allow that.
03-06-2024, 08:36 AM | #13 |
Rep 18
Can I mix and match Evolve with Bilstein B6?
I already have the Bilstein installed front and rear. I would just like to swap out the Evolve front to lower the ride height.
2013 E92 6MT
03-06-2024, 01:21 PM | #14 |
Rep 243
This seems like a really great product. Perfect for those wanting to retain EDC and go with an OEM+ damper.
-Thumbie
2011 Jerez E90 M3 6-speed Competition Package |
03-06-2024, 11:34 PM | #16 |
Rep 5,595
The difference in front strut length is going to be pretty small. They adjust the length to account for the gas lifting force in monotube damper. Although, they’ve never quoted a number, it’s around a 1/4-1/3”. People with their f8x version, complained about the increase in ride height because Evolve recommends the MSS HAS kit which has a mild drop to begin width. Are you going to buy two new fronts for 1/4-1/3”? As for mixing, that really depends on how different the comfort and sport+ settings are compared to the regular B6. EDC is trying to minimize oscillations so if there’s a large difference in damping then it may not be wise to mix B6 versions, if it’s small then it’s likely not an issue.
Nairb167.50 |
03-08-2024, 09:36 AM | #17 | |||
Rep 520
We always recommend following BMWs instructions and therefore recommend having the EDC system reset after installing our dampers. However if you do not have the tools to do this I don't think it's the end of the world to not have. Obviously each car is different and your mileage may vary. Quote:
It's been a very long time since being in a car with the Ohlins R+T setup. I would say our combo is the same or more comfortable purely from the point of view that when driving I don't find myself thinking it's uncomfortable or that I want it softer. |
03-09-2024, 12:26 AM | #18 |
Rep 2,824
Nice sounding product! Glad to see these finally on market.
Matt@Evolve1973.00 |
03-19-2024, 06:06 PM | #19 |
Rep 156
Installed mine over the weekend - very pleased with how the car now rides and handles the twisty backroads.
From a ride height perspective. How many miles till the suspension settles in - a few hundred? |
03-20-2024, 07:56 AM | #20 |
Rep 520
It depends on usage, but we measured the ride height fairly regularly and started to see a real difference around 400 miles, with it fully settled at roughly 1000 miles.
I’m sure to a degree time also influences this, and of course how much travel the damper is seeing etc. I’d recommend taking a measurement now and then remeasure every few hundred miles. |
