06-14-2021, 09:33 AM | #1 |
Rep 368
Well, my F30 has developed a sound akin to a 30 year old mattress frame. I have ruled out the shocks and can't seem to replicate the sound from the ctrl arms. So I'm thinking it's most likely the rear ball joint.
I have the ball joints ordered and on the way, but my question is has anyone replace these with a store bought ball joint press? I have a HarborFreight nearby and it looks like they have a 4wd press kit. I see the official BMW tool is available on eBay, but it is $250. |
06-14-2021, 10:37 AM | #2 | |
Rep 3,957
sspade2468.50 |
06-14-2021, 12:34 PM | #4 |
Car Hypochondriac
335
Rep 903
Drives: 2014 335i M-Sport Estoril Blue
Mine also creak. I just bought a bushing press from amazon that I am using today to remove the other bushing in the hub that goes to the trailing arm. If it goes well, I'm going to do my ball joints as well.
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
06-14-2021, 05:42 PM | #5 |
Rep 368
Cool, if that works out let me know which tool you bought. I don't mind spending a few bucks but $250 is pretty steep for a tool I'll likely use once
06-14-2021, 09:41 PM | #6 |
Car Hypochondriac
335
Rep 903
So, it worked, but it was a colossal pain in the ass. The kit I bought was $43 on amazon, "Heavy Duty Ball Joint Press & U Joint Removal Tool Kit".
It didn't come with a collar small enough to press the bushing all the way through the knuckle, I ended up using a 24mm socket and that was perfectly sized. I'd recommend a kit with more pieces that are smaller, will help a lot.
giraffewt15.00 |
06-15-2021, 09:32 AM | #7 |
Rep 368
Cool, I think I found the one you were talking about on Amazon. It looks like they don't list sizes for most of these kits. But it does look like they all have similarly sized components unless you buy a really expensive kit. I see that advance auto has a 23 piece kit available for rent. I think I may go that route, and just use a socket like you did if the appropriate size is not in there.
Did replacing the parts take care of your squeaking sound? |
06-15-2021, 09:53 AM | #8 | |
Car Hypochondriac
335
Rep 903
I haven't done the ball joint yet, I did the trailing arm bushing that's in the knuckle.
06-15-2021, 03:34 PM | #9 | ||
Rep 368
06-17-2021, 04:33 PM | #10 | |
Car Hypochondriac
335
Rep 903
06-17-2021, 04:42 PM | #11 | |
Rep 368
06-17-2021, 07:51 PM | #12 | |
Car Hypochondriac
335
Rep 903
06-17-2021, 09:14 PM | #13 | ||
Rep 368
Tricky part the bmw bushing is 1.860" diameter. If I use 1-3/4" OD pipe the wall thickness is lighter to fit over the internal part of the bushing… so it may not hold up to pressing. It's .063", so it could possibly hold up, hard to say without trying it, its really not something they put in the spec sheet. If I use 1-1/2" black gas pipe as a ram its 1.900" diameter. Nice and thick and heavy wall, definitely won't crunch, but I'd need to shave off .004". Would be easy if I had a lathe. Could Maybe try chucking it in a drill and shaving it down. Not sure what I'll try yet, but luckily the car isn't down so I can pontificate : Nothing on these cars is ever easy! |
06-18-2021, 09:47 AM | #14 |
Car Hypochondriac
335
Rep 903
I managed to get mine out! Turns out I'm and idiot and was pressing on the lip of the ball joint itself instead of on the knuckle... once I used a bigger cup to brace against the knuckle it broke free and it was out in less than a minute.
Now to get the new one back in... I put the new one in the freezer and hopefully that makes it a bit easier to press in. Oh by the way, the dealer wanted $1100 for the ball joint service. I said give me my car back lol.
06-18-2021, 01:11 PM | #15 | |
Rep 787
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
06-18-2021, 06:14 PM | #17 |
Car Hypochondriac
335
Rep 903
Well, it's done.
View post on imgur.com Leaving the other side alone until I get the proper tools. The smaller cup I used to push it in was ever so slightly wider than it needed to be, and so it wanted to slip off the beveled edge of the ball joint. Also, once I got it in, it wanted to go in at an angle. I kind of said yolo and kept pushing it in, eventually it actually popped back into a neutral position and became easy to push in until the last 1/2cm or so. That last 5mm was a COLOSSAL pain in the ass.
06-18-2021, 06:20 PM | #18 |
Rep 368
Oh, I know what you mean with the edge of the bushing being beveled. So if the installer cup had a thicker wall so it didn't sit on the bevel it would of worked correct? I have a friend bringing over some pipe tomorrow that I'm going to see if I can make work.
06-18-2021, 06:26 PM | #19 | |
Car Hypochondriac
335
Rep 903
To get it in, I used the smallest cup that came with my amazon tool. It was maybe .1" too wide in diameter to properly sit on the edge of the ball joint. That made it a huge pain. If I had a cup that could sit perfectly on the edge it would have been a breeze, I think. Also, I'm thinking choice in ball joint may play a part here. Maybe some manufacturers don't bevel the edge of the ball joint as much? I ended up rounding off the edge with that cup :/
06-18-2021, 06:39 PM | #21 |
Car Hypochondriac
335
Rep 903
Like you said, the ball joint's an awkward size, and that like 1/10th or 1/8th of an inch makes a big difference.
09-10-2021, 05:11 AM | #22 |
Rep 3,957
I was taking another look at the tools used since I may attempt this in the winter or early spring.
So for some background, to convert a BMW tool number into a part you can order, you just prefix it with "8330". Based on the BMW procedure, the following tools are needed: 0496552 Spindle --> 83300496552 ($95) 333010 Minimum set: Mechanical tools AM 2240471 Holding sleeve --> 83302240471 ($23) Minimum set: Mechanical tools Mechanical tool 2240466 Washer --> 83302240466 ($12) Minimum set: Mechanical tools Mechanical tool 2240472 Washer --> 83302240472 ($21) Minimum set: Mechanical tools Mechanical tool The most expensive part is the spindle part. Pricing is from getbmwparts.com. Last edited by Polo08816; 09-10-2021 at 06:15 AM.. |
