F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Car won’t start! Need help!!!
proTUNING Freaks
      04-14-2024, 07:09 PM   #1
E90ROXS
E90ROXS's Avatar
225
Drives: E90
Update 4/24/24
-Further investigation linked to the 2 resistors on the FEM and KOMBI
-Will do a termination resisting test through CAN-hi and CAN-low
Update 04/17/24
-Retested the fuses with a meter - all were working
-Did a software reset option from the secret menu in the cluster - all modules are responding now
-I connected the battery to a battery tender overnight - battery is 12.4+ V
-Looks like the error codes from MHD pointed to DME and powertrain physical wiring fault
-ISTA shows a bunch of other codes (even after I cleared them, they still came back)
https://drive.google.com/drive/folde...usp=drive_link
I was working on the dme and might have shorted something. The car doesn’t start anymore. All fuzes are good. I also unplugged the battery for a few hours.
I got 2 codes:
CDA840A - DME: Powertrain CAN: Communication fault
CDA683 - DME: Powertrain CAN: Line fault/electrical fault
Appreciate if someone can chime in and give me some suggestion on where to look.
      04-17-2024, 09:57 AM   #2
samspiderman3125
samspiderman3125's Avatar
46
Drives: 2017 440i gran coupe
I got 2 codes:
Attachment 3434744
what car?
      04-17-2024, 04:29 PM   #3
E90ROXS
E90ROXS's Avatar
225
Drives: E90
It's a 2016 340i. I did a software reset and now all modules are responding but some still have faults. I also checked all fuzes, all good. Car is still not starting.
https://drive.google.com/file/d/1ZCV...usp=drive_link
      05-07-2024, 03:40 PM   #4
E90ROXS
E90ROXS's Avatar
225
Drives: E90
So I found out the DME did not send crank signal.
f30post
