F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > F30/F32/F33 Classifieds (For Sale / Trade / Wanted) > Members Classifieds > Electronics: Audio / Video / Phone / Alarm / Navigation / Radar > FS: Match PP82DSP w/ HiFi Harness and Power Wiring
ARMA SPEED
      07-27-2023, 09:37 AM   #1
ask007
Drives: 2014 F30 328i xDrive
USD 475.00
Shipping Costs Included
Match PP82DSP Amp, Hifi Wiring Harness, and 6ft Power Cables with 40 amp fuse block pre-installed from knukonceptz
Similar to the bimmertech options available. The main difference is that the power comes directly from the battery instead of via the harness (20 amp vs 40 amp fuse). Does not have a metal mount to clip into the factory amp location as the bimmertech option has.
Requires HiFi Sound System (676) systems (will not work with HK systems!)
Amp is in great condition and was used for two years on my F30. Will need to be reconfigured with a new configuration file once connected to your car (unit needs to have an input source to be turned on and Windows laptop connected)
Configured to have G and H as sub channels, so you can also hook up an aftermarket sub if you want. Remote turn on out is available from the amp.
Includes USB Cable and Manuals
The positive cable will connect directly to the battery via 10MM socket
Negative cable can connect to a post near the factory amp in the wheel well
Shipping is included for United States buyers
      07-28-2023, 04:51 PM   #2
devioushaikuzero
Drives: 2013 328i
Is this plug and play like the Match Up 7BMW?
      07-28-2023, 10:32 PM   #3
ask007
Would not be full plug and play like that model. This setup requires power from the battery directly and a grounding point on the car. Cables are included and there’s a 10 MM bolt on the positive terminal that I’ve used with no issues and a negative post on the top of the driver side rear-wheel by the factory amp.
To install the amp, you’re pulling the carpet off anyways, so it only adds a couple of minutes to the install the power wires.
      08-03-2023, 05:26 PM   #4
ask007
Price drop! $475
      08-22-2023, 02:04 PM   #5
kovalchuk71
kovalchuk71's Avatar
Drives: F30 335i
PMed
      08-22-2023, 02:06 PM   #6
ask007
Originally Posted by kovalchuk71 View Post
PMed
Replied
      08-23-2023, 06:10 AM   #7
TriniGT
Trinidad_and_tobago
55
Drives: E30, E60 M5, E87, F20, F30
Will this work with not HK or HiFi but a basic/entry level setup that I am looking at upgrading along with upgraded seat subs, and HK pillar tweeters and possible an additional sub in the trunk?
      08-23-2023, 08:59 AM   #8
ask007
You will need to code your car to HiFi for the amp to recognize the low-level "balanced" signal properly.
Here's some more information that should help: https://f30.bimmerpost.com/forums/sh....php?t=1801823
Tags
amp, audio, bimmertech, f30, match, pp82dsp, pp86dsp, sound
f30post
