F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > ICM High Flashing / Update
ARMA SPEED
      05-01-2024, 05:38 PM   #1
esi183
Drives: 2013 F30 330d
Hi all,
I’ve recently successfully retrofitted 2VF / adaptive suspension on my 03/2013 330d. As part of this I installed a new ICM High (the correct pre-07/2013 part which is compatible with my DSC). I have no system errors on ISTA and the system is fully functional.
However I’ve got a couple of ICM ghost errors (Info Memory) - 4827A0 and 4827A4, which are pitch- and yaw rate errors. I first identified these through Bimmerlink but then investigated with INPA_Fxx which has some error activation conditions but ultimately has left me none the wiser. I have also tried extensively researching the significance of these online but have found very little info.
I thought that flashing my ICM might help, given the current ICM software date is 28/05/2012 and my car is on a 2018 iLevel. However eSys only shows a CAFD update available (-147 -> -148, see photo) which was tested with several sets of psdzdata full (ranging from 2015-2021) and trying many different iLevel shipments. (As an aside, If I select an iLeve shipment of 03/2012 or earlier the HWEL and all the BTLD/SWFLs become blue/red, but the SWFLs are older than my existing SWFLs so that’s probably for an earlier ICM which the incorrect part).
Trying to flash (cdeploy) the -148 cafd doesn’t seem to work and always reverts back to the older cafd. Interestingly, the info memory errors disappear after flashing until the next ignition cycle, so I wonder whether - if there’s a way to update the cafd and maybe also a newer swfl (if available) - then these errors may disappear.
It’s probably a butt dyno/placebo, but my feeling is when these errors aren’t present the car’s less bouncy over small imperfections - but I’m definitely taking that with a pinch of salt.
I’d be grateful for your advice re: whether an ICM update actually exists!
Thanks in advance for your help and suggestions
      05-02-2024, 03:04 AM   #2
Siki78
Siki78's Avatar
145
Drives: F30,G30
Try to edit your cafd in svt to 148 and then vo code.
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      05-02-2024, 04:45 PM   #3
esi183
I managed to detect CAF for SWE and inject the -148 file, but the ICM reverts back to the old -147 CAFD after the car goes to sleep. Is there anyone with pre-07/2013 ICM flashing experience - I’d be bery surprised if there are absolutely no SWFL updates since 2012.
Equally - is there any way of using a post-07/2013 ICM (which I also have sitting around haha) and FDL-code it to interface with the old DSC MK60, instead of the MK100 which it expects to see? Currently that newer ICM gives me a restraint error.
      05-03-2024, 06:08 AM   #4
Siki78
Siki78's Avatar
145
Drives: F30,G30
Read ecu don't read vcm. Delete existing cafd 147 and write 148 then vo code ecu
      05-07-2024, 11:16 AM   #5
esi183
I did it properly connected to a battery charger and this has worked. Didn’t solve my ghost errors though ha ha! Thanks for the help
Tags
flash, icm, update
f30post
