09-18-2016, 03:30 PM | #1 |
Rep 3,742
Replace panel w/ start/stop and sunshade switches
I recently deleted my car's rear sunshade and never use the auto start/stop feature. As such, I have zero need for that control panel with those two switches and would thus like to delete that panel to clean the interior up a bit.
I cannot for the life of me find the part number for the clean panel in that spot. Can anyone help a brother out? I am referring to the panel seen just above the little cubby above the DCT shifter in the photo below (although, unlike the panel in that pic, my seat heater switches are in the A/C unit; that panel is where the sunshade and auto start/stop switches are): |
09-18-2016, 06:03 PM | #2 |
Rep 133
Looks like it's called radio trim; #10 from link below.
https://www.getbmwparts.com/parts/20...gramCallOut=13 Part Number: 51459118703 center bezel w/navigation Part Number: 51459137564 center bezel w/o navigation |
Hujan569.00 |
09-18-2016, 09:38 PM | #3 | |
Rep 3,742
If so, that would leave me back at square one. I guess I'm hoping there is a piece that deletes that entire strip of buttons (basically the above piece but without the lower of the two cutouts). Failing that, I would settle for a strip of buttons without any buttons designated. |
09-19-2016, 11:39 AM | #4 |
Rep 3,387
The panel containing the buttons contains blank button faces. It's modular so if you had the kit, you simply pull off the seat heater faces and put on the corresponding blanks in their place.
https://www.ecstuning.com/BMW-E92-M3..._All/ES168433/ I have the kit but I'm planning on using it for another project to stealth up some of my add-ons But, the piece you're wanting, I actually ordered a few months ago as mine was peeling. I'll get you the part number when I get home. Edit: here you go, part number 51459118703. https://www.ecstuning.com/Search/Sit...8703/ES119249/ Last edited by whats77inaname; 09-19-2016 at 12:16 PM.. |
Hujan569.00 |
09-19-2016, 01:31 PM | #5 | |
Rep 3,742
09-19-2016, 11:20 PM | #7 | ||
Rep 133
lol |
Hujan569.00 |
09-20-2016, 07:28 PM | #8 |
Rep 3,742
Chuck's M3162.00 |
11-10-2019, 01:20 AM | #9 |
Rep 2,824
11-11-2019, 03:55 AM | #10 |
Rep 457
There's space in there, you can just leave the button row hanging. I don't think it likes being disconnected but I don't remember. It might default to start/stop on when disconnected.
11-11-2019, 11:38 AM | #11 |
Rep 2,824
^ Ah, interesting idea. Though knowing it's not "tidy" behind the panel may trigger my OCD. Easy swap, I imagine?
Default auto start/stop to ON would be hellacious! |
11-11-2019, 12:08 PM | #12 |
Rep 457
Very easy, I lifted the transmission leather panel then just pried it off. Might not even be that complicated but it runs the lowest risk of scratching any soft-touch plastic.
Could use some gaffer’s tape to stick it down without leaving any adhesive residue. |
11-09-2023, 02:57 AM | #13 |
Rep 100
Drives: '21 A90 Supra 3.0, '11 E92 M3C
quick bump on this - was this ever resolved? I also only have 1 button (2011.5 with auto start stop) and would like to replace with a clean no button panel piece as my trim is starting to peel slightly as well.
Wondering if there's enough room behind the panel to keep the button hanging or what the workaround fix is here- TIA!
2021 A90 Supra 3.0 Nitro Yellow, 2011 E92 M3 Comp Jerez Black
Instagram @hans.device |
11-09-2023, 12:20 PM | #14 | |
Rep 3,647
I replaced mine a few years ago as it was all nicked up from the original owner. I seem to recall there being plenty of room behind there if you want to hide that start/stop button. |
11-09-2023, 02:04 PM | #15 | |
Rep 100
Thank you!
