F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > bmw f30 transmission malfunktion
GetBMWParts
      03-12-2018, 08:59 AM   #1
hakisalapaki
Drives: BW 2012 F30
Exclamation bmw f30 transmission malfunktion
Hi all,
I have a problem since 1 month..
The problem is exactly same as the video.
I have checked,
-gear oil leak
-mechatronic
-Selanoid
-door sensors etc..
can any help?
but i have found out,if i press one time to gas pedal,transmission is working again.btw there is no warn light or messages.
      03-12-2018, 10:41 AM   #2
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Sounds exactly like auto-hold, but not sure if that should shift into park for you: http://www.bavarianmw.com/guide-2506.html
May have something to do with your parking brake?
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      03-12-2018, 01:58 PM   #3
valetudo81
Drives: 2013 328i F30 N20
Bunker J
I was going to say the same thing. Is this happening while parked on a hill/uneven parking surface?
      03-13-2018, 08:00 AM   #4
hakisalapaki
Drives: BW 2012 F30
actually not i am parking it in normal surface,there is no hill..
Brake is also working well..
      03-13-2018, 08:05 AM   #5
hakisalapaki
Drives: BW 2012 F30
i have also read bavarianmw,thank you,still not solved..
      03-13-2018, 08:50 AM   #6
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
If you're going to do your own work you need a code reader, like the Foxwell NT510. Without one you can't identify faults.
      03-13-2018, 09:04 AM   #7
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Check your transmission fluid and see if it's low. You may need to drain and fill, but don't flush it. If not that, check your battery and parking brake actuator.
      03-13-2018, 10:18 AM   #8
drivef30
drivef30's Avatar
Drives: 17' 340i xDrive M-Sport
Check codes and report back. Otherwise no one can help you
      03-13-2018, 12:02 PM   #9
Billfitz
Billfitz's Avatar
I doubt that, it's as if he tried shifting without a foot on the brake. If the shift controller isn't getting the message that the brake is depressed that would explain it. Which of the myriad of sensors is responsible for that who knows. It would take a code reader to trace it.
      03-13-2018, 12:37 PM   #10
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
I only say that because the guy in the video he linked successfully solved his problem by doing that. Not saying it's it, but it's a possibility. A code reader would help though.
      03-14-2018, 09:58 AM   #11
CandyRedRC46
CandyRedRC46's Avatar
242
Drives: 2013 328i
FWIW I have been told by the dealer and a few BMW Techs, that "These are sealed lifetime transmissions. You can't drain and fill (I asked for them to do it as preventative maintenance) and if you could or did, you would void the warranty." And also "Do not touch the transmission unless it is acting up (more than a simple CEL code)"
The same tech told me that the Drivetrain/Transmission Malfunction was due to the battery age and not being able to correctly operate the start/stop function...
      03-14-2018, 10:13 AM   #12
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
http://f30.bimmerpost.com/forums/sho....php?t=1016592
      03-14-2018, 10:19 AM   #13
CandyRedRC46
242
Drives: 2013 328i
"Transmission GA8HP70Z with N57 engine from 03/2011"
Not sure if that is the same transmission on the +2013 N20's ZF 8 speed autos?
      03-14-2018, 10:20 AM   #14
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Not sure if that is the same transmission on the +2013 N20's?
00 11 500 Checking/topping up oil level in automatic transmission (GA8HP45Z,GA8HP70Z,GA8HP90Z)
That was just a condition for that transmission.
      03-14-2018, 11:21 AM   #15
Billfitz
Billfitz's Avatar
It's not impossible, and with a six year old car a new battery isn't a bad idea. But I wouldn't pay dealer prices for a battery. You just need to have it registered, and any shop that regularly works on BMW can do that.
      03-14-2018, 11:22 AM   #16
CandyRedRC46
242
Drives: 2013 328i
Hmmm, So I guess the dealer and tech are full of it. I am at 80 k right now. I would definitely like to start doing drain and fills every other couple engine oil changes, as preventative maintenance.
I have been doing this on my old Acura since 150k and I am at 210k now with no issues. But that car is so simple, it would be stupid not to. Just remove drain plug, wipe clean, reinsert drain plug and the pour 3 quarts in through the dip stick. It only adds 5 minutes to a typical engine oil change. The acura transmission system holds about 9 quarts total, so a few 3 quart changes back to back and then a every other few engine oil changes gets the fluid in good shape and keeps it that way.
      03-14-2018, 11:30 AM   #17
Billfitz
Billfitz's Avatar
Changing the ATF is a PITA, but by no means impossible. IMO changing the fluid without changing the filter is a waste, which means dropping the pan, perhaps even replacing the pan, so I wouldn't be inclined to do this at less than 60k mile intervals.
      03-14-2018, 12:04 PM   #18
CandyRedRC46
242
Drives: 2013 328i
Yeah that sounds fair enough, being that you are changing the pan/filter/gasket/fluid etc....
      03-14-2018, 12:18 PM   #19
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
To say the least, yes. They have to follow what BMW tells them, just like the timing chain guide issue. If it can be done for preventative maintenance, then I agree it should be done.
      11-01-2018, 07:27 AM   #20
hakisalapaki
Drives: BW 2012 F30
dear friends,
now i am back after 7 months,with same problem again.(will not shift into reverse or drive,goes back to P) first of all thank you all for suggestions.
I have to inform there is no error code listing after malfunction.Secondly i found that this problem accours only in winter time.
third: i found a solution,if i step on the gas 2-3 times over 3000 rpm,then i can shift again,till next morning all the day without failure.
any suggestions?
      11-01-2018, 07:56 AM   #21
insanecoder
Drives: 340isDrive
dear friends,
any suggestions?
how did you check the solenoids?
has th tranny fluid been changed and how often
      11-01-2018, 08:49 AM   #22
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
dear friends,
any suggestions?
Yeah, there has to be something wrong here. Maybe a calibration issue or a sensor. It seems the car won't shift when the transmission fluid is dead cold.
f30post
