F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > F80 M3 controls arms install questions
GetBMWParts
      10-03-2018, 12:19 PM   #1
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Hey yall:
I am definitely considering this, well correction, considering this depending on cost as my budget as always is super constrainted.
F80
What do you guys think of this? Anyone done the same?
Outstanding questions I have at this point.
1. arm part numbers
right - 31122284530 - $208
left - 31122284529 $208
2. headlight control rod part number -
Whole kit including arms and control rod - $386
https://www.ecstuning.com/b-genuine-...31122284529kt/
3. proper torque - ???
Worth it?
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
eleven11374.50
      10-03-2018, 12:21 PM   #2
Daftasabrush
Fool
Daftasabrush's Avatar
England
1857
Drives: F31 340i
Funny you should mention this, I've been looking into this too
      10-04-2018, 11:11 AM   #3
Daftasabrush
Fool
England
1857
Drives: F31 340i
It should be noted that you also really need the tension struts as well as the control arms. With just the control arms the wheel moves a long way forward in the arch as you can see in the video. F80 tension struts fix that.
      10-04-2018, 11:04 PM   #4
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
I appreciate the info.. interesting those are needed too? Wonder if there is real benefit from doing this?
      10-05-2018, 01:07 PM   #5
jh_f30
jh_f30's Avatar
1308
Drives: 2013 335i Sportline Auto RWD
yeowtch!
I'm a fan of bkkeys so seeing this sucks. Gotta be honest though, I did chuckle at the vid a little bit, in a sympathetic, nervous laugh kinda way. He seems in fairly good spirits and definitely toftt!
https://www.youtube.com/watch?v=iL_Xgl-Hb-s
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      10-05-2018, 01:26 PM   #6
52172
52172's Avatar
Drives: 2015 Bronze Metallic 335i
I'm doing this def worth it better bushings and more neg camber
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s.
      10-05-2018, 02:01 PM   #7
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Ive also been looking into this.
Anyone completed this DIY ?
      10-05-2018, 03:04 PM   #8
anotheran
Sedan Driver
Drives: A nice car
Was going to do it for my car a while ago but realized it wouldn't work on xDrive. I'd do it.
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK
BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug
      10-05-2018, 03:19 PM   #9
MacklinUSOB
Drives: f30 328i 6MT Sport
It turns out he himself had an xDrive car and attempted this. Now we all know exactly why you cannot do this on an xDrive car. I watched the video in the top post before and assumed he had RWD, guess not.
For those with sDrive, this mod was very worth it. They improve all elements of steering and give much more grip on the front end through all corner phases. I did not do tension struts. The TS do not correct the wheel placement in the well (I later swapped to F80 TS and they mildly corrected placement, pushing the wheel further back and outward), the F80 TS are the same length as the F30 ones. The forward placement is not a problem clearance wise even with my car lowered and running wider tires/wheels. The F80 TS would be worth it for the bushings, but are not required.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
anotheran389.00
      10-05-2018, 04:09 PM   #10
anotheran
Sedan Driver
Drives: A nice car
For those with sDrive, this mod was very worth it. They improve all elements of steering and give much more grip on the front end through all corner phases. I did not do tension struts. The TS do not correct the wheel placement in the well (if they do it isn't noticible from posts i've seen), the F80 TS are the same length as the F30 ones. The forward placement is not a problem clearance wise even with my car lowered and running wider tires/wheels. The F80 TS would be worth it for the bushings, but are not required.
Oh damn... wish I could've told him that before he replaced it. In my tuning sheet i put this in back in 2016:
X BMW F8x lower control arms (spacers needed?) $169, 169, 169, 169 (31122284529, 31122284530, 31122284531, 31122284532) - won't fit xdrive suspension
      10-05-2018, 05:14 PM   #11
sspade
sspade's Avatar
Drives: F30
Is this an in the garage, on jack stands DIY or no?
      10-05-2018, 07:17 PM   #12
IK6SPEED
Drives: BMW M3 / AH3
Link to that thread? Search does not find it under your nick and would like to read.
As this adds negative camber, won’t the alignment shop attempt to correct that when aligning to factory specs?
Depends on the distance to alignment shop.
      10-05-2018, 08:31 PM   #13
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
The video has a solid walkthrough of the arms themselves, and the link to the kit has the arms AND the headlight arm you will need.
      10-05-2018, 08:37 PM   #14
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Originally Posted by jh_f30 View Post
yeowtch!
OMFG
I can only imagine the horror on this..
So still (sorta) thinking about this NON X DRIVE.. but what are the other parts folks mention? Last thing I want, or can afford to do, is break things trying for a little better handling.
      10-05-2018, 09:54 PM   #15
MacklinUSOB
As this adds negative camber, won't the alignment shop attempt to correct that when aligning to factory specs?
I don't live within 10 miles of one so I just bit the bullet and gave it to my Indy shop. The toe is massively thrown off and a good toe setting is very close to the ends of adjustment, that's what my shop told me at least. Not every alignment shop wants to do that kind of work, especially if you have coilovers and other mods.
Here is my coilovers only alignment:
And here is my post install and post alignment specs:
      10-07-2018, 01:44 PM   #16
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
huh.. this has that biting off more than I can chew right now feeling. Still need to change suspension, look at big brakes.. so on and so on.
      10-09-2018, 03:00 PM   #17
IK6SPEED
I spoke with someone who did this mod and ended up reverting it.
The F30 felt unstable with crosswinds on a highway to where he felt unsafe driving it.
anotheran389.00
BMWILUVU809.00
      10-09-2018, 03:21 PM   #18
sspade
sspade's Avatar
Drives: F30
I spoken with someone who did this mod and ended up reverting it.
Your talking about swapping the F80 LCA's onto an F30, right?
Do you know what other suspension setup he had?
Appreciate the insight as this is/was on my to do list to compliment my B8 / ACS set up.
      10-09-2018, 03:28 PM   #19
IK6SPEED
KW DDC coilovers
      10-09-2018, 03:36 PM   #20
sspade
sspade's Avatar
Drives: F30
KW DDC coilovers
Wow. Im honestly shocked.
Surprised a more aggressive LCA can completely ruin the way a car feels at highway speed to the point you would remove them.
Interested in other opinions from people with experience.
Thanks for sharing.
      10-09-2018, 04:16 PM   #21
52172
52172's Avatar
Exactly something wasn’t right all it does is add 1/2 deg neg camber nothing else.
sspade2468.50
      10-10-2018, 09:21 AM   #22
MacklinUSOB
Thanks for sharing.
Have had nothing like that experience nor read any other post from the hundreds I have on the topic claiming that, I must have missed that one.
Highway stability and tracking improved after the upgrade. I did a 1000 mile road trip a few months after having them installed and the increased caster improves centering force which keeps it tracking more true with less input.
Take a look at the threads on 2addicts on the topic, there are tons more people there who do this mod. The F22 and F30 share the exact same suspension architecture and geometry. Here's one of many, but a search for "F80 LCA" will get a lot of hits.
https://www.2addicts.com/forums/show...1079766&page=7
sspade2468.50
f30post
