11-16-2022, 01:03 PM | #1 |
Cheapskate
4462
Rep 4,995
B58 Water Pump DIY
I had a leaking water pump so I replaced it and made a DIY. Hope this helps
13
02-05-2023, 12:36 AM | #2 | |
Rep 90
I took the fan shroud off first and didn’t fully remove the charge pipe…just loosened at the top. Otherwise it was the same procedure and worked like a charm. Thanks for giving me the confidence to do this and save a ton of $! |
kern4174462.00 |
04-25-2023, 05:41 PM | #3 |
Rep 40
Drives: '16 340i Estoril/Saddle/THP
First, thanks Kern for the DIY! Second, is there a trick to pulling the fan out? I'm 0-2 on getting it out. I can get everything loose and pull it partially up but I can't get that tab on the drivers side to clear the hose to the radiator.
The first time I tried, I thought it was the resonator on the intake getting in the way (I'm stock and video clearly is not). I tried wiggling the intake all sorts of ways until the resonator snapped off. I duck taped the holes and ordered a replacement. 2nd attempt, I figured since I had to take the whole intake off, that I'd have all the room I need to get that fan out. Nope... Front, back, side to side, still couldn't get that tab to clear the hose. Does anybody have any tips? I might give it one more try otherwise I'll just have to bring it in and have the pros take care of it. It'll be far cheaper than breaking more parts.
2016 340i Estoril Blue/Saddle Brown M-Sport THP
2011 Z4 35i Midnight Blue/Red (Sold) 2006 330i Sprk Graphite/Black (Sold) |
04-26-2023, 07:18 PM | #4 |
Rep 44
Thanks kern417. Appreciate all you do for the community.
How'd you guys know you had a water pump failure? Pressure test? My coolant seems to be leaking somewhere in the system, again! Randomly checked my coolant reservoir today and noticed it was low. I had the majority of the hoses replaced last year (cost me 5K). Topped up the coolant and going to measure it over the next week. Thanks. |
04-27-2023, 10:10 AM | #5 | |
Rep 90
BeyondAddiction3.00 |
04-27-2023, 10:13 AM | #6 | |
Rep 90
04-27-2023, 10:16 AM | #7 | |
Rep 44
2016 340i | F30 B58B30M0
05-01-2023, 08:06 AM | #8 | |
Cheapskate
4462
Rep 4,995
Also, you're going to be draining a lot of coolant anyway, so you can remove some of the radiator hoses that are in your way. Random but i did the same job on my N52 X5 and the tab on the fan shroud swivels. I can't imagine why 10 years later they stopped adding that feature. (See top left) |
12-21-2023, 12:04 AM | #9 |
Rep 3
Thanks for the video, very helpful. My oem charge pipe is disconnected at the top but still attached at the bottom.
All 5 bolts have been removed. Any tricks to remove the water pump? Should it wiggle off or does it need to be pried off the block? Mine is stuck on there pretty good and I can’t get a screwdriver in towards the top of the water pump, like in the video. |
12-21-2023, 07:53 AM | #10 |
Rep 806
That lower charge pipe clip is a pain in the ass. I've only ever been able to get it off with two screwdrivers, one in each side at the same time. One screwdriver should do it, but three times now I've wasted 5-10 minutes trying.
Getting the fan in and out is also a pain. It's like a puzzle piece just be super patient and don't break anything. Eventually it finds it's way out. Plastic junk |
12-21-2023, 10:54 PM | #11 |
Rep 3
Update here. Im still stock (charge pipe, air box, etc). I was able to leave the lower charge pipe connected/clip intact.
I had a hell of a time removing the old water pump. What worked for me - there is a circular indent in the metal casting above the pulley that conveniently fits a 3/8” socket. Socket into the indent and lots of wiggling back and forth and was finally able to remove the water pump. Careful of the two locator pins (approx 12 o’clock and 7 o’clock). |
12-25-2023, 03:19 AM | #12 | |
Rep 1
02-03-2024, 10:11 PM | #13 | |
Rep 1
02-15-2024, 04:49 AM | #14 |
Rep 4
Can someone explain what is the extra pump with house (black) on the coolant pump
Can someone explain what is the extra pump with house (black) on the coolant pump of 340i ?
The left is new one, right is Old one in my car.: When I checked online, I can see parts with and without this black attachment, but both are same part number (11517643067) With attachment: https://parts.bmwofsouthatlanta.com/...ly-11517643067 Without attachment: https://www.ecstuning.com/b-genuine-...u/11517643067/ |
02-15-2024, 05:43 AM | #15 | |
Rep 452
02-15-2024, 02:15 PM | #16 |
Rep 4
02-17-2024, 11:20 AM | #17 |
Rep 452
