Go Back   M3Post - BMW M3 Forum > M3 Marketplace > SPONSORS Classifieds/Groupbuys/Specials Area > Suspension | Brakes | Chassis | Handling
      04-04-2017, 01:50 PM   #1
kevin @ eas
kevin @ eas's Avatar
Drives: 2015 BMW M4
▀▄ eas | AST Coil Overs - Authorized Dealer - [Master Dealer]
Our newest addition to the EAS lineup is AST coil overs
As a US importer we will carrying their full line up for all BMW's.
PM today for fitment info and pricing
AST 1-Way 4100
The 4100 Series shocks introduce high performance monotube technology at prices competitive with twin tube insert coilover kits. They include purpose built strut and shock bodies, shortened from stock lengths. All kits come with anodized aluminum adjusters that stay on the shock; no need to keep your pockets full of tools to make quick adjustments.
Features
- Monotube design shocks absorbers gives your car a better performance than the standard twin tube design, the gas pressure is separated by a floating piston and eliminates cavitation and airation within the oil chamber.
- The 4100 series shocks allow rebound adjustment with one knob.
- The adjust platform allows the user to adjust the ride height of your car.
- AST suspension shock bodies are specially designed to keep maximum stroke, even with a lower ride height and are finished with a KTL coating for an extremely hardwearing finish.
- Rebound Adjustable (“Singles”)
- 22mm diameter shaft struts, non-inverted
- Steel cylinder body shocks, non-inverted
- Optional DDP piston (double digressive)
- Optional spherical upper shock mount assemblies
- Optional DLC Coated shafts
- Re-buildable
AST 1-Way 5100 Series shock absorbers
The 5100 Series shock absorbers utilise inverted / upside down technology. The inverted design is race proven technology and produces an extremley strong damper, providing better suspension geometry under heavy lateral and braking loads as seen in a road and track environment.
The 5100 Series shock absorbers give your car a better performance than the standard twin tube design. With the 5100 Series suspension you can adjust rebound with one knob. The adjust platform allows you to adjust the ride height of your car. AST suspension shock bodies are specially designed to keep maximum stroke, even with a lower ride height.
Features:
High-end, track ready suspension that is totally streetable
Rebound Adjustable (“Singles”), without reservoir
44.5mm diameter shaft struts, Inverted
New low friction seal on all AST dampers
Rubber bushings for “eye” shock mounts
Optional Spherical lower “eye” shock mounts
AST 2-Way 5200
The 5200 Series are 2-way adjustable shock absorbers which are based upon competition 3-way adjustable shock absorbers. The 5200 shock absorbers are adjustable in compression and rebound.
The design of the compression adjuster is an evolution of the compression adjuster we provided for the American Grand-Am series for the last few years. The 5200 shock absorbers were designed to achieve a quick and easy set up, allowing separate adjustment of compression and rebound.
In the 5200 Series AST uses an external canister. Throughout testing and competitions, the 5200 has been praised for its performance and capabilities, surpassing other major, more expensive brands and setting a new standard of 2 way damper. Its no surprise that the 5200 is fast becoming a favorite damper amongst race teams and track day enthusiasts world wide.
Features:
- High end, track ready suspension that is totally streetable
- Fully upgradeable to 5300 spec
- Rebound and Compression Adjustable (‘Doubles’), with a remote reservoir
- Remote reservoirs allow additional travel and heat dissipation
- 44.5mm diameter shaft struts, Inverted
- New low friction seal on all AST dampers
- Spherical lower ‘’eye’’ shock mounts
- Reservoir with hose or piggyback
- Spherical upper shock mount assemblies
- Synthetic hydraulic fluid
AST 3-Way 5300
For the best performance on the track, AST Suspension designed the Competition 3-way adjustable series. The 5300 Series shock absorbers are rebound adjustable in 12 positions on the strut.
The highspeed compression is adjustable in 12 positions and the lowspeed compression is adjustable in 14 positions. Both compression adjustments are made using an external canister. All adjusters work completely independent.
Many years of technical knowledge, testing and experience has been refined, fettled and brought together to create a perfect balance between the choice of springs and the corresponding damping characteristics. This makes it a versatile product for every customer. The 5300 series shock absorbers are the best solution for every race team. Once installed te shock absorbers are easy to setup, highly reliable and require low maintenance during the season because of the high grade of materials used.
All of this together makes the 5300 series shock absorbers a championship winning damper, over and over again. The AST 5300 Suspension is worldwide renowned for its performance at every level.
Features:
- Rebound, Low & Hi Speed Compression Adjustable (‘Triples’), with a remote reservoir
- Optional DDP piston (double digressive).
Models Supported
2015+ BMW F80 M3
2015+ BMW F82 M4
Ordering:
Phone:
You can reach us directly by calling 866.669.0705 x31 to place your order over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone)
Other Payments:
Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Shipping:
All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees.
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday - 9AM to 2PM PST
Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell.
Contact Info:
Phone: 866.669.0705 x31
Email: kevin@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact me via PM, email, or phone if you have any questions.
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
      04-06-2017, 05:59 PM   #2
kevin @ eas
Drives: 2015 BMW M4
AST 5100's being installed @ EAS
PM today to get yours!
      04-18-2017, 04:49 PM   #3
kevin @ eas
Drives: 2015 BMW M4
Thanks for the inquiries
AST coil overs setups in stock and ready to go
PM today for options and details
      05-01-2017, 05:17 PM   #4
kevin @ eas
Drives: 2015 BMW M4
EAS your #1 source for AST coil overs
      06-27-2017, 05:47 PM   #5
kevin @ eas
Drives: 2015 BMW M4
AST 5200's featuring remote reservoirs
PM today for applications and details
      08-02-2017, 04:53 PM   #6
kevin @ eas
Drives: 2015 BMW M4
PM today for details and pricing
      08-23-2017, 11:43 AM   #7
kevin @ eas
Drives: 2015 BMW M4
AST 5100 series
In Stock and ready to ship
      11-17-2017, 06:18 PM   #8
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
EAS is your #1 AST dealer, call to get your AST coilovers today!
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
      07-18-2018, 04:00 PM   #9
kevin @ eas
Drives: 2015 BMW M4
Enjoy Moton/AST Summer sale
10% off
PM for details and pricing
      07-24-2018, 05:42 PM   #10
kevin @ eas
Drives: 2015 BMW M4
Enjoy 10% off on AST suspension sale
Take advantage while you can
PM for pricing and details
      08-01-2018, 05:29 PM   #11
kevin @ eas
Drives: 2015 BMW M4
Another set of AST's installed @ EAS
Save yourself 10% while you can
      12-05-2018, 04:38 PM   #12
kevin @ eas
Drives: 2015 BMW M4
AST coil overs ready to ship
      12-12-2018, 05:04 PM   #13
kevin @ eas
Drives: 2015 BMW M4
Save yourself 10% on AST coil overs
      12-17-2018, 05:12 PM   #14
kevin @ eas
Drives: 2015 BMW M4
Save 10% while you can
AST kits ready to go
      12-28-2018, 01:55 PM   #15
kevin @ eas
Drives: 2015 BMW M4
Hurry time is running out on AST winter sale
      01-14-2019, 03:53 PM   #16
kevin @ eas
Drives: 2015 BMW M4
      02-06-2019, 04:59 PM   #17
kevin @ eas
Drives: 2015 BMW M4
EAS your #1 dealer for ASt/Moton
      02-11-2019, 05:45 PM   #18
kevin @ eas
Drives: 2015 BMW M4
AST 4100 in stock and ready to go
      02-20-2019, 05:43 PM   #19
kevin @ eas
Drives: 2015 BMW M4
EAS your #1 AST/Moton dealer
      03-28-2019, 06:34 PM   #20
kevin @ eas
Drives: 2015 BMW M4
      04-08-2019, 06:42 PM   #21
kevin @ eas
Drives: 2015 BMW M4
      04-17-2019, 02:52 PM   #22
kevin @ eas
Drives: 2015 BMW M4
AST 5100 coil over sets in stock and ready to ship
