01-30-2016, 03:02 PM | #1 |
Rep 5,316
Drives: G80 M3 6MT
Before you ask why your exhaust is broken and why only one side is dirty: READ THIS!
This question comes up all of the time, so I have asked a moderator, Dackelone, to sticky this so it can be at the top of the forum for everyone to see, although I'm sure this won't stop people from asking still.
It is completely normal for exhaust gas to come out of only one of your two exhaust tips, and for only one to look dirty most of the time. This is because the exhaust on our cars is valved, meaning it has a "flap" inside one of the pipes, and can be controlled electronically by the car for various reasons. In most cases, the flap will be closed, and this is the default setting for both Eco Pro and Comfort mode, this is why you see one tip clean and one tip dirty. In Sport and Sport+, it is open. Here is a summary of the function of the flap (to my best knowledge):
If you car doesn't do what I described to the T, don't worry, it doesn't mean somethings wrong, the car's computer is very smart, and only under certain conditions will that flap open itself, so if you go out and start your car and it happens to be open, don't worry, maybe your cars already warm, etc, etc. Hopefully this thread will help put to rest all of the questions about this function so we can all get back to complaining about other small, unimportant things.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com Last edited by smithf80; 03-12-2016 at 08:33 AM.. |
38
arvi60461.00 BFVBFV0.00 nozydog465.00 Leopold1.50 Gimlitehdwarf55.50 exponology29.00 Sheharyar_rr236.50 trohde7874.00 Lance_Goodthrust4.50 Joe Vona5.00 Seba77W420.50 thanksalatte13.00 Soul_Glo13378.00 bgalakazam94.00 Peter 440i0.00 BMWinAZ104.00 godofzeus6.00 Milkman670228.50 aguywalksintoabar1688.50 julian20420.50 coldheat061.50 jimgandhi4.50 Bimgineer9.00 CJWALL0.00 ultimated27.50 GamaM4404.50 |
01-30-2016, 03:28 PM | #2 |
European Editor
10616
Rep 22,992
Great write up.
Cross posting this thread... F32 & F36 435i OEM Exhaust Valve Settings Different? http://f30.bimmerpost.com/forums/sho....php?t=1156577 Only one exhaust steam? http://f30.bimmerpost.com/forums/sho....php?t=1217585
Nathen424213.50 |
02-02-2016, 11:49 AM | #5 |
Rep 1,342
This is great. Maybe this sticky should be expanded / modified to include all FAQs for noobs?
- Exhaust on one side - No temperature sync button - Whirring noise when opening car door (fuel pump priming, i believe) - What happens if I use regular gas What else? |
02-02-2016, 12:23 PM | #6 |
Rep 4,724
On my MPE both pipes open up after warm up even in comfort. Which my previous two 35i models did not with the stock exhaust.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
02-02-2016, 12:24 PM | #7 | |
Rep 4,724
Which is better: xdrive or rwd? How can I change my halogen lights to HIDs or LEDs..?
02-02-2016, 06:13 PM | #8 |
Rep 2,080
Yeap, same here.
02-02-2016, 10:09 PM | #9 |
Rep 4,724
Moral of the story is: buy the MPE
02-20-2016, 10:35 AM | #10 |
Rep 91
So the next question is, with all of this software controlled flap nonsense going on, why not have a binary flag flip on each startup to in essence "rotate" the exhaust path used for warm up on each ignition?
02-20-2016, 04:39 PM | #11 | |
Rep 5,316
Drives: G80 M3 6MT
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
nozydog465.00 |
02-23-2016, 03:50 PM | #12 | ||
Rep 982
Nice of you to make this a sticky haha did see it being asked frequently! In addition though one question: On the 28i (and possibly also the 35i) I've noticed that cold start RPMS vary sometimes. Sometimes it goes to about 1650 and it starts up LOUD. Other times it goes to about 1450 and it's much quieter.. Engine had the same amount of time to cool down, sometimes days.. Car probably has a reason for it but I can't seem to find a pattern |
03-06-2016, 07:55 PM | #14 |
Skull Squadron Leader
307
Rep 2,031
2016 F36 435xi here. Exhaust valve logic for other F3x does not equate to F36. Tried everything, and CANNOT get the valve to open. If there's another '16 F36 owner that has figured it out... don't bother explaining it to me... I've gone to option 2, and it took less time compared to everything I've done above.
Decided to do the U-Clip disconnect. 10 minutes total DIY, and no need to disconnect any harnesses. Easy to reconnect if I ever need to. Here's a view of the clip in place from the other side of the exhaust: Here's the clip (on my work towel :-) ...and the wire that keeps the flap in the open position: |
03-07-2016, 10:20 AM | #15 |
Rep 1,056
I unplugged the actuator. It's now open all the time.
DarkStarBimmer208.00 Alpine-F80203.00 |
03-10-2016, 03:05 PM | #16 |
From Siberia to Switzerland
Rep 51
Hi, did you unplug it when the engine was running or no? I tried to unplug it with the engine off, and it let to the flap being always closed, even in the Sport mode.
2015 F32 435i M Sport | RWD | 19" 442M | 8AT | Black Sapphire | LCI Rear lights | Llumar ATR 15% | Mike's Customs downpipe | MPE | MPPK | MP Brakes | H&R 10/12mm spacers Previously: 2008 E92 335i / M-pack / RWD / 6AT / Frozen Grey |
03-10-2016, 03:08 PM | #17 |
Rep 1,056
I did it when engine is off. I verified it with a flash light that it's open.
03-12-2016, 04:08 PM | #18 |
Rep 4,724
Yes! They made this a sticky!!
03-12-2016, 04:09 PM | #19 |
Rep 5,316
Drives: G80 M3 6MT
Yeah, has been for a while, I PM'd a mod right after I made it. I was tired of seeing a new thread on this every... single... day.
Scott, Partner
03-12-2016, 04:13 PM | #20 |
Rep 4,724
Yes..., but you know the thread will still pop up.
03-12-2016, 04:18 PM | #21 |
Rep 5,316
Drives: G80 M3 6MT
Of course. Some people cannot be helped. I can only hope that it prevents a coupe of these threads from popping up.
Scott, Partner
03-16-2016, 09:02 PM | #22 |
Rep 1,733
Drives: 2003 M3
You unplug it at the exhaust? Not in the trunk like the E9x cars?
