F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > USA - California > smog test with Bm3
Extreme Powerhouse
      01-07-2022, 11:36 AM   #1
2BitRoach
2BitRoach's Avatar
Drives: 2016 328i f30 N26
smog test with Bm3
anyone in California smog test yet and pass while flashing back to stock with bootmode? this new rule in CA regarding tuned cars will fail smog test. wondering if we'll pass with the stock tune flashed back just for the test
      01-07-2022, 12:54 PM   #2
McGyv3r
Drives: 1989 325i & 2014 335i
2014 BMW 335i  [0.00]
1989 BMW 325i  [0.00]
Flash back to stock and lock the DME, this will pass the checksum. Do the drive cycle to set the reediness monitors, this will pass the monitors. Remove any mods that aren't legal in CA, that gets you to pass the visual.
eluded3070.00
soas0.00
      01-07-2022, 02:42 PM   #3
davidr3
Drives: 335i
Yeah just did mine. Flash back to stock lock the DME. Threw back on stock DP &did drive cycle and I passed.
      01-07-2022, 04:33 PM   #4
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Sticky this... 😂
      01-08-2022, 02:01 PM   #5
DarkF30
DarkF30's Avatar
54
Drives: F30 328i
On a side note would bms stage 1 tune affect the smog at all?
      01-08-2022, 02:34 PM   #6
muniz_ri
Drives: BMW 320I
I don't know but it's easy enough to unplug and avoid any hassle. I will be removing my JB+ just in case.
      01-08-2022, 04:36 PM   #7
Gen13 F36
Gen13 F36's Avatar
On the side note....why don't you try it and let us know
      01-09-2022, 12:35 AM   #8
2BitRoach
2BitRoach's Avatar
awesome thanks for the info , glad you passed. yeah I'll have to put back my stock downpipe also.
      01-09-2022, 01:49 AM   #9
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3070
Drives: 340 6MT, 50e, others
People always laugh at me when I tip my smog guy.
      01-09-2022, 12:28 PM   #10
davidr3
Drives: 335i
I had a guy that would look past the DP & any other mods but im not sure if they can get by the monitors
eluded3070.00
      01-10-2022, 02:24 AM   #11
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3070
If the tip is big enough sometimes those details are overlooked
      01-10-2022, 08:07 AM   #12
k3_b58
beemerw
k3_b58's Avatar
Drives: 2016 BMW 340i M Sport
Aren't they CARB legal?
      01-10-2022, 09:57 AM   #13
muniz_ri
Drives: BMW 320I
Not for the N20.
      02-25-2022, 12:26 PM   #14
chuckles01
Drives: 2014 328i Sport, 6M
Hopefully not a stupid question but anyone *not* flash back to stock and actually fail or get flagged? Now that this law has been implemented for a while, I'm just curious how thoroughly they do check, and whether this is more of a scare tactic or an actual crackdown on tunes.
2014 BMW 328i, 6-speed
Prem / Nav / Drivers Assist / Heated Seats / Lighting
      02-28-2022, 11:01 AM   #15
McGyv3r
Yes. Someone on here flashed back to stock, but didn't lock the DME. They failed and were sent to a referee.
It's not a thing about being thorough, its about math and it's automatic. The checksum is just adding up all the 1's and 0's in the DME's code. Compare that value to a known good value. If your checksum is off, you fail. Any changes to the factory tune will change your value, so you fail.
exE36M3491.00
      03-09-2022, 03:37 PM   #16
Danielknguyen
Drives: BMW F31
I just passed smog with MGFlasher flashed back to stock and relocked the ECM - did drive cycle in a day and was ready for smog the next. I left the Xhp Transmission tune active and had no issues.
      03-09-2022, 09:15 PM   #17
BushF30
Drives: 340i
dumb question, if i flash back to stock and lock the dme, do i have to get it the dme unlocked again or can i flash back the ots tune?
      03-10-2022, 10:05 AM   #18
McGyv3r
Yes, you will have to unlock it again before you can flash it with an OTS map. BM3 will lock/unlock the ECU for you.
Unlocking and tuning takes about 5 minutes. Re-flashing an unlocked DME takes about 2 min.
      03-11-2022, 12:21 AM   #19
stuckyducky
stuckyducky's Avatar
Drives: 2014 BMW 320i X-Drive
Just smogged my car today with BM3 flashed back to stock for CA Smog.
I originally tried to pass off a high flow cat for a smog. The guy failed me like an a hole, told me my oxygen sensor isn't ready and collected $75 anyways. I returned back to stock, took it to another place my house in SF. I told him I returned the intake, downpipe, and ECU back to stock. It's flashed back to stock with a stock map and locked ECU. He gave me a lecture about how I should protect the environment. He did a "light" inspection and hooked it up to the computer. He said the Smog computer gave the green light within 10 minutes, but I should still do my part in keeping it stock.
So if you flash back to stock for BM3, LOCK the ECU after flashing back to stock and drive for at least 100+ miles for oxygen sensor to reset and other crap. I drove 400 miles.
exE36M3491.00
      03-12-2022, 10:17 AM   #20
exE36M3
BMW CCA Member
exE36M3's Avatar
491
Drives: 2015 435i M Sport
stuckyducky - thank you.
This is the simplest to follow BM3-smog-process I've read so far.
I got to do the same next year and I'm pretty much all stock and on stage-1.
      03-31-2022, 02:34 PM   #21
Gen13 F36
Gen13 F36's Avatar
Amen!
You live in California, that is your reality. Just go back to stock every 2 yrs for smog. You don't like it then there are other 49 states to move too.
I use to pay $300 to pass an SR20DET powered Silvia. California life.
      04-01-2022, 01:06 PM   #22
Doug435i
Drives: BMW 435i
FYI. I passed CA Smog with Stage 1 BM3 and stock down pipe in January with no issues.
f30post
