12-28-2020, 06:22 PM | #1 |
Rep 6,802
► APEX | APEX Race Parts Hardware and Accessories
Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST BMW Wheel Hardware and Accessories APEX Race Parts is proud to offer a full line of wheel hardware and accessories. From high quality spacers to colorful APEX center caps, we have your needs covered! Checkout the details below on our wide selections of high quality BMW wheel hardware and accessories. BMW Wheel Spacers Hardware Optional Extended wheel hardware is required for the installation of spacers, but if you already own studs or lugs, you shouldn’t be required to purchase hardware with spacers. APEX wheel spacers can be purchased separately from extended hardware so the choice is up to you. Buy them on their own or pair them up with a stud kit or extended lugs & locks. Easily Removable Save yourself from the headache. If you’ve owned spacers before, you’ve likely had one seized onto the hub. Instead of using a mallet to free it, utilize a tool meant for removal— a pry bar or screwdriver. Our spacers feature machine-cut pry points around the spacer’s edge, making even the most seized spacers a breeze to remove. Rotor-Matching Colors You’ve worked hard on the color scheme and coordination of your car and modifications. Spacers should not be any exception. They are meant to push wheels out, not stand out on their own. Available in two finishes— Black and Silver. Precise, Refined Construction Our spacers utilize the best materials available and employ military-grade construction methods. APEX wheel spacers are CNC machined out of 6061-T6 Aluminum and feature carefully chamfered edges, eliminated stress-risers, and an appropriately lightweight design without sacrificing rigidity or surface area. Easily Identifiable APEX wheel spacers are clearly marked with each specification and dimension to ensure you never confuse them with another set. OEM-Spec Manufactured to perfectly match the measurements and tolerances of your BMW, these spacers are a natural extension of your wheel hub. Cheap, hastily-made spacers are infamous for their sloppy construction, uneven surfaces, and out-of-round shape and result in poor fit & unsafe vibrations. Vibration Free Spacers are useless if they vibrate. We’re so confident that if our spacers cause any sort of vibrations or shakes, we’ll replace them. Simple as that. Order Now 3mm | 5mm | 12mm | 15mm | 18mm | 20mm OEM BMW TPMS Sensors and Colored Valve Stems OEM BMW TPMS Sensors The Huf/Beru TPMS sensors are made in Germany and are the exact sensors that came on your BMW. They don't perform like your OEM units. They are your OEM units. 1-year manufacturers warranty Black, Anthracite, and Silver valve stem finishes available See our vehicle application list to find the correct model your specific car Availability and Pricing OEM BMW TPMS Sensors $55.00 - $95.00 Pricing varies based on TPMS model selected. All sensors are sold individually. OEM Colored Valve Stems These OEM colored valve stems are compatible with OEM BMW TPMS Sensors and with no TPMS sensors at all. They are 43mm in length (identical to OEM), and are finished in colors that complement APEX wheels in any finish. The valve stems are made in Germany and are guaranteed to fit your OEM TPMS sensors. OEM valve stems come standard with plastic grooved valve caps. All finishes are free and included when you purchase one of our OEM BMW TPMS Sensors at the same time. Please specify your color selection at the time of purchase. Less Time: No more time spent trying to line up lug holes while holding wheels up with your feet. Studs make it easy to slide the wheel on and leave it there while grabbing the hardware. Lug nuts easily slide on and off the end of the stud, and can be started by hand with little-to-no effort. Use Any Spacer: All spacers require extended-length hardware to be used safely. With our extended-length studs, you are no longer required to buy a bucket full of various-length bolts for use with different size spacers. Our 75mm studs support up to 12mm spacers, and our 90mm studs support up to 25mm spacers. Available Sizes & Options Order Now M12x1.5mm 5 lug kit | M14x1.25mm 5 lug kit | M12x1.5mm 4 lug kit OEM and APEX BMW Center Caps APEX Colored Center Caps Add some color to your ride with APEX colored center caps! Available in Gloss Black, Blue, Green, Red, and Yellow. Every set of APEX wheels comes with Gloss Black APEX Center Caps. The colored Center Caps can be purchased as an optional extra to help make your color scheme stand out or provide some needed contrast. OEM BMW Roundel Center Caps OEM Roundel Center Caps are the perfect choice to finish off any OEM+ look. These Center Caps are the classy choice to make your car stand out from the rest! Order Now APEX Colored Center Caps | OEM BMW Roundel Center Caps Questions? Call: 925-245-0773 Email: expert@apexraceparts.com Web: www.apexraceparts.com Hours: M-F 9a-5p PST
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
01-05-2021, 05:02 PM | #2 |
Rep 6,802
01-19-2021, 06:58 PM | #3 |
Rep 6,802
02-11-2021, 12:52 PM | #4 |
Rep 6,802
02-24-2021, 12:56 PM | #5 |
Rep 6,802
04-01-2021, 02:37 PM | #6 |
Rep 6,802
06-22-2021, 04:15 PM | #7 |
Rep 6,802
12-15-2021, 03:58 PM | #8 |
Rep 6,802
Both M12x1.5mm and M14x1.25mm BMW stud kits are in stock and ready to ship! 75mm and 90mm options available with hex head or bullet nose studs. Follow the link below to learn more and order a set today! APEX BMW Stud Conversion Kits
