06-11-2016, 09:55 AM | #1 |
Rep 468
DIY: How to replace lower control arm
EDIT 24 August: added reply with DIY steps
The bushing on my lower control is degrading so I am looking to replace it. Two questions: 1. Does anyone have a guide on how to remove / install? I don't do much suspension work and am not that familiar with this kind of activty. 2. For daily driving and Occasional track use, should I bother with the upgraded bushings? Am thinking of just buying a replacement control arm from ECS or GetBMWParts...is an upgrade worth it? Am a little worried about pressing out the old bushing and pressing in a different one as opposed to just swapping out the assembly. Thoughts? Last edited by MTM; 08-23-2016 at 05:11 PM.. |
07-05-2016, 09:18 PM | #3 |
Rep 3,742
Drives: 2018 M2
I would rephrase the title. I doubt people read the title and can tell you have a question.
07-08-2016, 06:59 PM | #4 |
Rep 468
07-24-2016, 07:05 PM | #5 |
Rep 101
Is this what you are referring to (red arrow)? I bent mine at the last track day i was at. Ordered one yesterday, should be here Wednesday. Planning on replacing it this weekend. If that's what you are talking about let me know and ill make sure to document the process.
The Bad One The Good One
2011 E70 Xdrive50i M-Sport Black
2011 E92 M3 ZCP LeMans Blue 2006 E90 330i Silver - Donated after 410,000 miles |
08-07-2016, 09:41 AM | #7 |
Rep 239
There is a guide in the e90 3 series forum and should be very similar to your M.
www.e90post.com/forums/showthread.php?t=788761 Also this one for the "Tension Strut" www.e90post.com/forums/showthread.php?t=778726 |
08-23-2016, 05:36 PM | #8 |
Rep 468
DIY Edits
So I did the job this weekend. Assuming I did it correctly, the job was actually very easy.
Tools Used: 21 mm box end wrench 18mm box end wrench 18mm ratchet (open socket wrench or a deep socket) T-40 Torx bit (Small sledge to break loose the nuts) Overall Steps to Remove: Jack up car, be sure to keep wheel supported (don't let it hang loose) Loosen 21 mm nut on vertical stud of control arm (near wheel) When stud begins to spin, grasp 21mm nut and use T-40 on top of stud Remove 18mm nut near car frame (the bushing end of the control arm) Reverse the above to install. CAUTION: the left and right lower control arms look nearly identical! The only difference is which end the offset bushing protrudes from the arm. I missed this and got to do the passenger side two times (ugh!). Once you know what to do, the job only takes about 30 minutes. Maneuvering the bushing end of the control arm in and out of the frame bracket can take a little patience. The pic below shows the 18mm box end wrench and the 18mm open end socket on either side of the bushing stud. |
10-02-2016, 10:18 PM | #9 |
Rep 1,075
One thing very commonly overlooked, is any bushing needs to be tightened when the car is on its own weight.
If you tighten everything up when you are in the air, you are preloading the bushing, which creates a number of unintended consequences. |
11-23-2016, 08:13 AM | #10 |
Rep 1,407
Drives: 06' E46 M3 ZCP
Part number for lower forward control arm?
19’ F90 M5C | Signature VS-104 | M-Performance | IND | H&R
06’ E46 M3 ZCP | Karbonius | Ohlins | Vorshlag | Turner | Kassel | IND | Status Gruppe | Macht Schnell 03' E39 M5 | 100% Stock |
03-18-2017, 12:27 PM | #11 |
Rep 769
Would that still apply if I am installing control arms with mono ball bearings instead of bushings?
03-18-2017, 12:35 PM | #12 | |
E90
167
Rep 821
Not quite sure how I would even get under it to tighten it if the car was on its own weight. |
03-18-2017, 12:41 PM | #14 |
E90
167
Rep 821
Hrm, true. I only have access to a 4 post or 2 post lift and have never worked with ramps before. Hopefully it's a non issue since our new bearings do not flex like the stock bushings can.
03-18-2017, 12:46 PM | #15 | |
Rep 769
Lol but for real I want a lift so bad, I'm jealous. But anyway, you're probably right. |
03-18-2017, 01:30 PM | #16 |
Rep 1,171
03-18-2017, 02:52 PM | #17 |
Rep 769
Ok, FWIW, I just talked to my friend who's a Nissan master tech and he was saying the reason you aren't supposed to torque down a rubber bushing without load is because the control arms will twist/turn slightly once you set the car down and since rubber bushings are not made to turn inside the "socket" the rubber will just twist which can cause them to crack/break prematurely due to constant stress. But since bearings are made to turn, then it's no issue!
03-18-2017, 04:10 PM | #18 | |
Rep 2,362
What I do is lower the front onto ramps, crawl under and torque it down. |
07-10-2018, 02:40 PM | #19 |
Rep 365
how many of these self locking nuts would I need? I will be taking out the control arm bushings and installing stiffer bushings then puting the original control arms in again.
https://www.ecstuning.com/b-genuine-...h/33326760668/ |
01-27-2019, 06:29 PM | #21 | |
Rep 112
05-22-2021, 01:33 AM | #22 |
1967
Rep 1,927
I'm doing the control arms based on the FCP Euro video on it, but struggling to take off the tension strut on the T40 bolt side. The bolt will not spin at all, broke 3 T40 sockets on it.
Any tips for getting it off? Thinking of resorting to an impact wrench and a T40 impact socket, but that might strip the bolt and cause a bigger problem. |
