08-17-2020, 04:45 PM | #1 |
Rep 354
DIY for Hub Replacement front/rear
Curious if anybody has a DIY for wheel hub replacements? I am looking to do either the future classic or core4motorsports F80 M3 hub conversions to take advantage of 14mm wheel studs. The front looks mostly straightforward but the rear is more of a question mark for me at least. TIA!
'18 Fire Orange F80 M3 - 6spd, ZCP, full M-performance catalog, Forgeline GA1R
'95 E36 M3 - Widebody S54, PTG Tribute, 315s square, TC Design built racecar Instagram - @Boondogglegarage |
08-31-2020, 10:37 PM | #2 |
Rep 542
I did it with the hub in place following these instructions:
https://www.ecstuning.com/resources/...rsrc=bvadomain Rent this tool, instructions above used the same tool and it made the work very easy. https://www.oreillyauto.com/detail/b...5632404?pos=13 get this tool to pull the axil into the hub https://www.ecstuning.com/b-bav-auto...kaAh14EALw_wcB Last edited by atopa2002; 08-31-2020 at 11:02 PM.. |
08-31-2020, 10:45 PM | #3 | |
Rep 542
Here you go mate. Not a m3, but same job.This guy is meticulous and took his time to how the steps . GL |
03-29-2021, 09:24 PM | #5 |
Rep 1,055
Bumping this, in watching a diy video, it mentioned that the bearing should be pressed a certain direction because the orientation matters to the function of the speed sensor.
Can someone comment as to whether this matters with the E9x bearings? I'd hate to press them and learn that I put them in the wrong direction. |
