08-01-2018, 06:18 PM | #1 |
Rep 8
Bimmer Tech Amp Upgrade PP82DSP
Just sold our beloved 2014 to make room for a people mover to accommodate our latest family addition. Before selling, I took out the Bimmer Tech amp I bought and installed last year (April 2017). Installs in about 30 minutes thanks to plug-and-play harness. Works like a charm and made a HUGE difference in the sound quality of my Hi-Fi sound system (option code 676). We loved the default DSP settings but you can customize it to create your own DSP profiles (see related threads on this forum). Amp sells at Bavsound for $997 plus tax. Asking $600, shipping to lower 48 states included. Thanks, Phil |
08-02-2018, 09:26 AM | #2 |
Rep 8,942
You should point out that it comes with wiring harness and mounting bracket which if purchased alone is $200 from Bimmertech and can take up to a month to arrive. So someone would have to find an amp for $400 or less then buy and install that to beat your deal.
Would be also good to say specifically which tune is preloaded if you know. I know for a fact that the tune Bavsound loads for their speakers is different than what Bimmertech loads for their speakers.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
08-03-2018, 04:13 PM | #3 |
Rep 8
Those are great points, BEM-S4. Thanks a lot for the nudge!
So, yes, the amp comes with the mounting bracket and the wire harness that seamlessly plugs into your BMW's existing harness. I'm afraid I don't now exactly which tune Patryk at Bimmertech put on the amp before shipping. And I'm happy to throw in the USB cable that you need if you want to customize the DSP profile. Hope this helps. I'll post some pics shortly. |
08-04-2018, 09:25 PM | #4 |
Rep 8
As promised, here's a pic showing the amp with the mounting bracket, wiring harness, and the USB cable I'm throwing in (used to customize the DSP settings). Thanks for looking!
08-04-2018, 11:20 PM | #5 |
335i F30
68
Rep 252
This will work with the HK system?
13' F30 335i Mineral White Metallic
Sport Package | 19" Rotiform SPF | BC Coilovers Coral Red Interior | H/K Package Active Autowerke Flash Tune, FMIC, Exhaust | BMS Intake | VRSF DP | VRSF CP |
08-05-2018, 10:12 AM | #6 |
Rep 8
TMac335i, the Bimmertech Amp will not work on the HK system.
See here: https://f30.bimmerpost.com/forums/sh....php?t=1295895 Thanks for looking! |
08-08-2018, 11:43 AM | #7 |
Rep 5
Interested in the Amp, but since I have the base audio system. Will I need additional wiring to run from the HU to the AMP -> speakers?
Also do you post overseas? I am based in the UK |
08-13-2018, 12:34 PM | #8 |
Rep 14
Tags |
amp, amplifier, bimmer tech, bimmertech, dsp, pp82dsp |
