12-19-2014, 01:37 PM | #1 |
Rep 52
Supercharging my car.... are all my bases covered?
I'm putting the ESS VT2-650 kit on my car and also having the rod bearings replaced as a preventative measure. I have HFC's X-pipe, and axleback. Is there anything else I should definitely do? I've heard some talk of replacing the differential bushings... Curious to hear any thoughts.
12-19-2014, 01:59 PM | #2 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Especially as a Manual trans I would replace the rear diff bushings for sure, I am among many who have snapped the rear diff bolts do to the squishy OEM ones. SC will only compound the problem, will also get rid of wheel hop and plant your rear much better.
Depending on what your doing and how the diff falls when the bolt/bolts snap you can cause some serious damage. That being said if you get solid mounts you will get some NHV, will hear a slight whine at different speeds that can be heard even over exhaust and supercharger. ESS SC is pretty quiet at first untill it fully breaks in around 1500 miles or so then you get more of that SC whine action.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc Last edited by squartus; 12-19-2014 at 06:55 PM.. |
12-19-2014, 05:32 PM | #6 |
Rep 2,002
I think your good man.... good suggestions here but unless your drag racing you can get by for a bit. Get a boost gauge that shows AFR as well. I'd look at the p3 gauge. You want to watch AFR and boost to make sure everything is operating as it should.
Your going to love the power! congrats
ESS 650 ACM-R Upgrades |
12-20-2014, 12:32 AM | #8 |
Rep 1,130
12-20-2014, 02:41 AM | #9 |
Rep 3,217
I would also change the spark plugs. Dif fluid. Trans fluid. Engine oil and so on. Just to be safe. I'm sure you know that already good luck!
e92 ///M3 |
12-20-2014, 01:46 PM | #10 |
Rep 2,301
It's an entire kit, that locks down the rear differential to prevent wheel hop during hard launches. Without it, you risk snapping your drive axles, if you launch from a dig.
'07 335I w/ Mods
'13 X1 Stock '11 X3 K&N |
12-20-2014, 08:58 PM | #11 |
Rep 1,536
+1 on the DEFIV DCT brace, I am very glad this product came to market. Not as clean a solution as solid diff mounts, but doesn't introduce cabin whine, which is important. Super stocked to get mine.
12-21-2014, 05:45 PM | #12 |
Rep 1,130
Are you sure it doesn't? My buddy is running a similar brace on his mustang and it's LOUD.
12-21-2014, 09:45 PM | #13 |
Rep 1,536
12-21-2014, 10:34 PM | #14 |
You got my money?
3201
Rep 4,683
Drives: Ice Cream Truck
I heard that brace DOES add noise.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
12-22-2014, 01:13 AM | #16 | |
You got my money?
3201
Rep 4,683
I thought most noise = solid diff mounts. Some noise, but not nearly as much = solid subframe. And I was told by a owner of the defiv kit that it added a lot of noise to his (which makes sense if they use solid diff mount) car. Im actually having my car super charged tomorrow at EAS so I would like to know what to order next and make sure I know what is the best for me.
12-22-2014, 01:04 PM | #17 |
Hamann M3 Fan
298
Rep 2,885
Drives: E92 M3 & F10 M5
You are just about good bro
All you need to do is your Diff bushings and your rear sub frame bushings if you go solid you are going to hear the diff whine. Then sit back and enjoy your ESS 650
JZB,6MT, My mods 360 Forged 20inch wheels,VF650 Supercharger custom tuned,ARH Long Tube Headers,Hamann CF roof spoiler,H&R springs,CF grills,Hamann rear trunk spoiler,Hamann Side Skirts, ARKYM full CF bumper, Gintani Race exhaust, ARH X-pipe catless,RPI scoops,AA SSK, Arkym CF Double Sided Vented Hood, |
12-22-2014, 01:25 PM | #19 |
Rep 212
12-22-2014, 01:28 PM | #20 | |
Hamann M3 Fan
298
Rep 2,885
You are correct go this route and you should be good. No diff whine
12-22-2014, 04:12 PM | #22 |
Rep 52
Would this kit do the trick you think?
http://www.ecstuning.com/BMW-E90-M3-...ial/ES2651068/ |
