11-16-2018, 01:17 PM | #1 |
Rep 29
I have a 2015 328i and I opened my exhaust flap by unplugging the wire so I was wondering can I get a plug that I can use that will give me oem look or something like that because right now I have the wire tapped and zip tied.
11-16-2018, 01:23 PM | #2 |
Rep 91
I don't remember from where exactly (thinking it might be the same place that was selling the ASD delete harness) but it was fairly expensive (like30-40$).
Edit : After literally a 5 second search on google : https://www.ecstuning.com/b-genuine-...r/18302411427/
'18 230i xDrive// Black Met // Coral Red // M-Sport // BM3 // BMS Intake // BMS OCC // Dinan Axleback // Daily Fun
11-17-2018, 12:54 AM | #3 |
Rep 537
Plug it back in and use BimmerCode+Bimmerlink to code it open.
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
11-18-2018, 08:30 AM | #5 |
Colonol Forbin
208
Rep 338
11-18-2018, 11:45 AM | #7 |
Rep 16,194
Makes sense, the default position in case of component failure should be the one that doesn't hinder the operation of the car, which would be open. Not that open doesn't affect the operation of the car, it does by causing longer warm up times, but that's not a safety issue, whereas a loss of acceleration capability in a passing situation would be.
11-18-2018, 12:39 PM | #8 | |
Rep 227
Drives: 2000 BMW E39 M5
11-28-2018, 06:06 PM | #11 |
Rep 891
My actuator broke during a track day, I left it plugged in but removed the connecting pin and secured the flap open with metal picture wire. Not an elegant solution but it was cheap and doesn't throw a code, car has to be off the ground to see it.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
11-29-2018, 04:11 PM | #13 |
Rep 5,460
Drives: F30
12-04-2018, 02:02 PM | #14 |
Rep 463
12-05-2018, 08:34 AM | #16 |
Rep 120
Drives: 2015 BMW 428i
I used BimmerLink to leave my Exhaust Flap open. I used BimmerCode to code my ASD to the Model and Engine of an M4.
It is TRULY a significant sound/motor difference with my exhaust and the M4 ASD coding. |
02-03-2023, 09:32 AM | #17 |
Rep 1
I've got both Bimmercode and Bimmerlink and my bimmerlink app does not show any control for my exhaust flap and was told by those guys that my car may not be configured right. Does anyone know of a way to check through bimmer code to make sure it's programmed correctly? I've dug through it pretty well and haven't seen anything so I'm hoping that its something I missed.
02-03-2023, 02:23 PM | #18 |
Rep 133
The best solution is the one I did, you buy this part 18302411427, it is the dummy flap actuator that the performance exhausts of the 30i and 40i have, it is totally compatible and also leaves no faults in the control unit. In addition to canceling completely if it is the case of having the actuator motor, in Aliexpress I also bought the connectors and sealed them with silicone to prevent moisture https://es.aliexpress.com/item/32877...d=siM6RdVdCvob
these are the pieces |
