01-09-2022, 05:00 PM | #1 |
Rep 2
E90 320si compatible LSD?
Hi new to the forum
Currently planning a 320si build and wondering if there are any compatible aftermarket LSDs currently in the market? Love that the engine was homologated for the WTCC - I really geek out on that kinda stuff - so don't mind that it's not got as much grunt or character as the 6 cylinders. I'm also aware of the the issue with cracked cylinder heads and happy to do some work to prevent any failures. So far I've found a number of LSDs that are compatible with the E90 325i, 328i, and 330i such as the Wavetrac LSD l, but I'm unsure if this will work on the 320si. I don't have loads of technical knowledge so any advice would be great thanks )) |
01-11-2022, 03:21 PM | #3 |
Rep 2
Thanks @firefly96!
Just found a compatie helical LSD from Quaife. Birds are their main dealer in the UK - £919 for the diff, £1392 with fitting. Link: https://www.birdsauto.com/quaife/sea...51014&mi=320si |
01-12-2022, 10:01 AM | #4 | |
Rep 8,171
The 320si is very cool, I've seen only one in person! Share your progress with it in the E90 forum if you want.
