      05-15-2019, 08:21 PM   #1
Green-Eggs
Drives: BMW
Thumbs down BMW (finally) publishes S65 Rod Bearing Clearance Specs
There's a new and "shocking" development for the people following the BMW S65 rod bearing issue. After 10+ years, BMW has finally published their rod bearing clearance specifications. To put it mildly, the specs are shocking and are worse than we had imagined.
Every time a new TIS is published, Bert checks to see if BMW has finally published the rod bearing clearance specs. Such was the case last week when Bert was researching the rod bearing specs for S63 motor. That's when Bert pulled up the S65 engine specs, and noticed that they finally contain rod bearing clearances. [LINK]
The specs aren't good and confirm a worse-than worst case scenario. When Van Dyne measured the original bearings @ 0.0013 inch, they didn't imagine that was at the top end of the clearance specs. Stewart Van Dyne gave the following comment over the phone: "Well, BMW just confirmed that they're doing what we all know doesn't work."
Minimum clearance: 0.0004 inch
Nominal clearance: 0.0009 inch
Maximum clearance: 0.0013 inch
* Same information is posted in the Bearing Clearance Wiki thread.
Appreciate 17
SoCalRPM885.50
Iyzmi802.00
Scharbag2620.50
BrewRifle419.50
Mvy540.50
derbo3610.00
dparm3849.50
Law6381.00
inTgr8r2431.50
DrFerry6728.50
L4ces337.00
      05-16-2019, 11:48 AM   #2
Helmsman
Helmsman's Avatar
Sweden
4467
Drives: 2011 AW E90 M3 ZCP
Thanks Green-Eggs, how interesting! Yeah certainly seems to be on the (extremely) tight side and assumingly a good reason to the wear issues we see. BMW engineering certainly been around so bit of a mystery.
These numbers also make me curious about your own measurement of BMWs shell which comes out with quite a bit more clearance?
Nominal Rod Bearing Clearance 0.0381mm
Bearing Clearance Variance 0.0292 - 0.0508mm
Just trying to understand what we're comparing here.
Thanks
DrFerry6728.50
L4ces337.00
      05-16-2019, 12:24 PM   #3
Siajoon
///Majestic
Siajoon's Avatar
Drives: 2011 E90 ///M3
So does this mean all of us who paid out of Pocket are going to get reimbursed for our RB job... loll
OG Shark4692.50
DrFerry6728.50
L4ces337.00
      05-16-2019, 12:26 PM   #4
slicer
slicer's Avatar
2739
Link doesn't provide the same info found in body of your post. Is there another location with that info. Thanks for posting this!
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
DrFerry6728.50
      05-16-2019, 02:08 PM   #5
Helmsman
Helmsman's Avatar
Sweden
4467
Believe it does: 10-34um with the 22um half way inbetween.
DrFerry6728.50
      05-16-2019, 02:28 PM   #6
derbo
Derbo Tuning
derbo's Avatar
3610
Drives: BMW M3
so now what?
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
SF Bay Area: DM For coding services
      05-16-2019, 05:23 PM   #7
slicer
slicer's Avatar
2739
I believe that "connecting rod play" is side play - not bearing clearance.
'23 X7
      05-16-2019, 05:57 PM   #8
ItsGary
ItsGary's Avatar
Drives: 2009 E90 M3
One could only hope but that won't happen
'09 335i Coupe - Alpine White/Black - SOLD
      05-16-2019, 07:11 PM   #9
Green-Eggs
Drives: BMW
Thanks
This is just the data, no other comparisons are implied. We'll leave that to others to discuss and debate.
One thing about those numbers, you' pulled them from the 702 bearings, not the 088 bearings. Since these specs just appeared 10+ years later, we have no idea whether they are for both bearings or not. My personal opinion is that the specs between 088 and 702 bearings didn't change. I know that goes against the general opinions of others. I think those measurement differences are rather insignificant. 0.5/10000 to 2/10000 of an inch difference between paper specs and measured specs is pretty insignificant IMO.
DrFerry6728.50
      05-16-2019, 07:12 PM   #10
Green-Eggs
Drives: BMW
Correct. The numbers are the same.
DrFerry6728.50
      05-16-2019, 07:17 PM   #11
Green-Eggs
Drives: BMW
Bert looked at this and discounted it for two reasons:
1. Side clearance is typically 10x - 35x larger than these values. If these were side clearance values, the engine wouldn't last.
2. The S63TU engine and other BMW engines also list these specs but add the word "Radial" to them. For S63TU, it's very clearly bearing clearance specs as the wording is consistent across many BMW engines. Here's the link: https://www.newtis.info/tisv2/a/en/f...rings/GIecw87b
Still being concerned with the odd wording, Bert checked with Indy and NASCAR engine builder friends. Both confirmed it meant rod bearing clearance; side clearance was therefore excluded.
DrFerry6728.50
      05-16-2019, 07:27 PM   #12
tdott
Drives: M3
Great to finally get confirmation what we pretty much knew all along. Or actually it is slightly worse than we thought, but we knew it was less than industry standards.
Queue those who don't know anything coming in to say...."but BMW must know what they were doing and must have done it for a reason."
DrFerry6728.50
      05-16-2019, 09:50 PM   #13
dparm
Stop the hate, get a V8
dparm's Avatar
Well it's not like BMW has never built engines before. A bearing clearance is not something they just arbitrarily pick, this shit goes through a lot of R&D. That being said, we don't have any information about what kind of data led them to that design. It's very possible it was based on bad data.
Past: 2011.5 M3 sedan ZCP
      05-16-2019, 10:04 PM   #14
SoCalRPM
SoCalRPM's Avatar
886
Drives: e92 M3
Thanks for the info, OP. Similar to what someone asked in the parallel thread on this issue - why did BMW do this?
Perhaps, the tight clearance stems from some kind of performance based standard that originated in F1 or some other racing development? If they carried over specs from race engines that likely see rebuilds long before road-going passenger vehicles ever would, then maybe there wasn't sufficient data on the long-term reliability.
I suppose it's immaterial, the clearance data itself being outside of industry standard should be enough to deter them.
Ultimately, it still comes down to either BMW didn't know, or worse, they didn't care.
      05-17-2019, 07:34 AM   #15
Helmsman
Helmsman's Avatar
Sweden
4467
Looking at your (BE's) measure of the 088 shells the number is 0.0152 - 0.0533 also with an assumed average of ~0.04mm clearance, again almost twice the assumed average of BMW. With a difference that big something is in my mind strange.
For what its worth it seems that at least the 702 shell often comes out around 0.04mm using plastigage, which would match your own number pretty well.
DrFerry6728.50
      02-02-2024, 08:55 PM   #16
Assimilator1
Assimilator1's Avatar
United Kingdom
594
2010 BMW 330d  [8.00]
2008 BMW M3  [0.00]
Old thread I know, but still relevant.
I've recently been involved in an argument over at m3cutters regarding S65 bearing clearances and rod bearing problems (some there don't believe it's a clearance problem...).
As a side shoot from that discussion Paul Gros of MAR Motorsport, an official seller of Mahle MotorSport bearings etc (& he's apparently formerly from Mahle itself), has dipped his toes into it, and then in a separate thread posted clearance specs for the OEM lead/copper bearings which he states are not made by Clevite, but by Mahle/Glacier Vandervell and that the "mean clearance was 0.046mm and the grading scheme allowed a total range of 0.029/0.062mm"
It would seem the figures from TIS (& AIR) are not the rod bearing clearances....
And it would seem the OEM mean (nominal) figures aren't as tight as we thought, although still less than industry standard and BE bearings and Mahle Motorsports own bearings.
Seems to me the OEM ones are still somewhat on the tight side, especially at the lower end, just a little less tight than we originally thought (in respect to nominal clearances, not measured).
Thoughts?
      02-02-2024, 09:20 PM   #17
charliev68
charliev68's Avatar
204
Drives: bmw m3
Does anyone know of any other engine that runs a similar tight tolerance successfully?
DrFerry6728.50
      02-02-2024, 09:26 PM   #18
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
Old thread I know, but still relevant. I've recently been involved in an argument over at m3cutters regarding S65 bearing clearances and rod bearing problems (some there don't believe it's a clearance problem...).
It would seem the figures from TIS (& AIR) are not the rod bearing clearances.... And it would seem the OEM mean (nominal) figures aren't as tight as we thought, although still less than industry standard and BE bearings and Mahle Motorsports own bearings. Seems to me the OEM ones are still somewhat on the tight side, especially at the lower end, just a little less tight than we originally thought (in respect to nominal clearances, not measured). Thoughts?
What is the source of information posted by Paul Gros? Sorry for not reading his entire thread. Not that it matters, but over the last 14 years of contributing to this forum I developed quite a negative view of the U.K. based m3cutters forum (and some of its members) especially with regard to the entire S65 rod bearing saga. Paging "Green-Eggs".
      02-02-2024, 09:33 PM   #19
DrFerry
Field Marshal
DrFerry's Avatar
Drives: '08 E92 M3
2008 BMW M3  [5.25]
2015 BMW X5  [4.50]
The Honda S2000
Honda S2000 (F22C1)
Engine capacity - 2 ltr
Engine power - 237 hp
Hp/ltr - 118.5
Redline - 8000 RPM
Preferred oil spec - 5w30
Rod bearing clearance variance - 0.02-0.06mm
Crankshaft pin/rod journal diameter - 49.988mm
Clearance to Journal Size Ratio - 0.008mm
S65 specs
Engine capacity - 4 lts
Engine power - 414 bhp
Bhp/ltr - 103.5
Redline - 8300 RPM
Spec'd oil - 10w60
Nominal rod bearing clearance - 0.0381mm (0.00150")
Rod bearing clearance variance - 0.0292 - 0.0508 mm (from BE's S65 wiki for the later Alu/tin shells, which apparently have a slightly higher minimum)
Crankshaft pin/rod journal diameter - 51.9786-51.9887 mm (official specs posted in the S65 wiki)
Clearance to Journal Size Ratio - 0.0007mm
Source Assimilator1 's thread:
https://www.m3post.com/forums/showthread.php?t=1827360
      02-03-2024, 01:09 AM   #20
Adam M
Drives: BMW e92 M3
I started the initial discussion thread over on m3cutters and after a private email conversation with paulgros, I found myself hanging on his every word. His engineering and specifically bearing knowledge is almost encyclopedic.
The key point is that the numbers that started this thread are definitely the correct ones for con rod play and con rod play is very much not the same as clearance.
It seems that a lot of people have been taken in by an incorrect assumption.
The oem nominal clearance is certainly bigger than is being touted here. Main reason for UK skepticism is the disproportionate number of failures you have had compared with us. It suggests there’s something else going on, other than just slightly lower than normal rod bearing clearance.
      02-03-2024, 01:32 AM   #21
2226cc
Drives: M3 E92
The Honda S2000
Honda S2000 (F22C1)
Hp/ltr - 118.5
Redline - 8000 RPM
S65 specs
Bhp/ltr - 103.5
Redline - 8300 RPM
Spec'd oil - 10w60
Interesting to see the difference in chosen oil thickness, I’m running a high quality 5w40 in my s65 and really curious how the bearing will look, probably doing them next winter
DrFerry6728.50
      02-03-2024, 03:18 AM   #22
PaulGros
Drives: BMW E46
The source of the information is the original Glacier Vandervell drawing.
DrFerry6728.50
