10-15-2021, 04:57 PM | #1 |
Rep 143
New Tires FTM Issue
I just installed new tires, going from 255/35-19 & 275/35-19 to 275/30 and 295/30 and ever since they were put on I get a FTM "Flat Tire" warning every 100km or so. I check pressure and it's all even and good and initialize the FTM but it keeps coming back.
No codes on the DSC or ABS modules. Any ideas?
2013 Fire Orange II E92 M3 ZCP
Bimmerworld (Quad) Resonated X-Pipe, AFe Stage 2 CF Intake, Carbon Project CF Plenum, Epic Motorsports Race Tune, Rogue Engineering Power Pulleys, Continental Extreme Contact Sport |
10-17-2021, 08:18 PM | #2 |
Rep 161
Did you replace the TPMS sensors, or is this one of the cars that used wheel speeds to detect low tire pressure? If it's #1 you may need new TPMS sensors. If it's #2, the FTM system may be freaking out about the new tire diameters.
10-17-2021, 09:19 PM | #3 |
Rep 836
Drives: Jerez E92 M3 ZCP "12"
I have same Tire setup with Michelin PS4s and got new HUFF TPMS Sensors installed on all 4 wheels. I have Forgestars F14 wheels with super deep concave...after install. simply reset Tire pressure calibration through your idrive. I have zero issues.
10-17-2021, 09:35 PM | #4 | |
Derbo Tuning
3612
Rep 3,026
Unfortunately, you are resetting correctly. I'm not sure what would cause that issue though.
IG:ruhrohz_m3
Expressivedrives249.00 |
10-18-2021, 02:24 AM | #5 |
Rep 108
I use F 255/35 R19 R 275/35 R19. No Flat Tire warning, works OK.
May-be it does not like rear 275/30 decreased diameter? Do you run 2,4 bars front pressure and 2.6 bars rear? I have an experience of running F 265/30R19 89Y and R 295/30R19 100Y Toyo Proxes R888 R. No light.
M3 E92 ZCP LCI
10-18-2021, 06:15 PM | #6 |
Rep 836
oops, my bad,,,,just realized OP stated FTM instead of TPMS...my apologies. hope someone is able to help you with your issue.
