F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > BMW E28 M5 CSL Custom Build
proTUNING Freaks
      12-16-2011, 09:31 AM   #1
JimVR4
JimVR4's Avatar
Drives: 21 X5 M50i M-Sport
BIMMERPOST
     Featured on BIMMERPOST.com
Im new to this forum, and thought it would be a good place to publish the car we have been building for some time.
Since the E9 3.0 CSL is possible to buy, we didnt choose that easy path when it was time to build our new race car...
First, we retired the E28 M535i we used to run in the racing series.
Attachment 621332
And then we bought in a scrappy old 528i to experiment with...
Attachment 621333
Once it was welded to the wanted shape, we made molds of it, and scrapped it out. Molds and other items seen here.
Attachment 621334
Then we stripped down the M535i and prepared a S38B38 Evolution engine for the new car...
Attachment 621335
Said and done, we made some new fenders in the molds, and put them on to the car to see what we had created...
Attachment 621336
BBS wheels for rain and for dry was invested and stored.
Attachment 621337
Off to the paint shop, and back it came...
Attachment 621338
Some assembly time later it looked like this...
Attachment 621339
Attachment 621340
And next to a stock M535i it looks like this...
Attachment 621341
Attachment 621342
And when all is put together and the colour scheme was completed, it made its first apearence in the race!
Attachment 621343
Attachment 621344
Attachment 621345
Attachment 621346
The car has been struggeling with some strange problems all season and didnt perform any results to brag about so far. Once all problems seemed sorted out, a new one came, and this time it was a hard one to find... Fuel hoses that wont stand the high octane race fuel and therefore melting slowly inside, rubber parts get stuck in the fuel injectors and the car runs lean and wont rev up as it should.
Jegs has now shipped a better hose and we look forward to the next (final) race that takes place in October 10.
The rear doors are welded in place and wont open unless Hulk Hogan manages to find the handle...
I will try to publish some technical specification if its for anyones interest.
And regarding the photoshoot with a real CSL, it has already been made...
Attachment 621347
Attachment 621348
Attachment 621349
The rear doors are totally cut out and its just a frame holding a fibre glass door sill in place, almost no metal left at all, all windows are of 3mm lexan plastic and all bodypanels are of composite materials, suspension and chassie mainly of aluminum.
There is however at least another 50 kg (150 lbs) more to reduce and it will be made in near future.
The front wings are about 2-3mm thick and very light, and equipped with the M5 E60 vents, in true CSL Batmobile style
Wheels are BBS RS 3-piece 11x16" in front and 12,5x16" in the rear. Light and beautiful.
Attachment 621350
Attachment 621351
Attachment 621352
Attachment 621353
Attachment 621354
Ok, i guess its time to write some technical information about the car, if you dont mind.
Some short and basic information:
Body: BMW E28 w/o sunroof, rebuilt to coupé, extended FIA safety rollcage, raceweight aprox ~1100kg with driver. Vented body - 200mm (8") wider in rear, 160mm (6.3") wider in front.
Engine: BMW S38B38 (6-cyl 3.8l-24v 365hk/8000rpm)
Gearbox: Getrag 260, shortshifted 5-speed.
Final drive: BMW M3 Group A limited slip, 4 different gear ratios available.
Front brakes: 6-piston aluminum calipers, 330mm (13") rotors.
Rear brakes: 4-piston aluminum calipers, 303mm (12") rotors.
Wheels front: 10x17” BBS (rain), 10.5x16” BBS (slick).
Wheels rear: 12x17” BBS (rain), 13x16” BBS (slick).
Tires front: 275-17” rain, 11,0-23,5-16” slick.
Tires rear: 335-17” rain, 12,5-25-16” slicks.
Chassie / suspension front: BMW Motorsport/Schnitzer 635CSi Grp.A. Suspension arms extended to allow more aggressive settings, wheelbase extended by 40 mm (1.6"), and track width extended by 80mm (3.1").
Chassie / suspension rear: BMW Motorsport/Schnitzer 635CSi Grp.A, Suspension arms fully adjustable for camber/caster and toe. Reinforced A-arms and all stiff mounted joints, no rubber in attachement points.
A lot of the spec is similar to the E9 3.5 CSL when it comes to tire dimensions and type, spring setting is also similar to the ancient race car, shock settings are similar to the classic E24 635 factory racers and the data has been partly collected from BMW Motorsport, Germany.
The rollcage is a copy of the one used for 1982 ETCC winner BMW 528i E28 once the aluminum cage was cancelled.
There is a lot more to write, but this is what comes to mind at this point. Let me know what you need information about, and I will be hapy to provide you all with it.
Attaching a pic that was taken for a car magazine a few weeks ago.
Attachment 621355
2021 G05 X5 ///M50i / Phytonic Blue / Cognac Vernasca
iStep 03/2023.50
      12-16-2011, 09:34 AM   #2
AddictedToBavarian
My other ride is a Bianchi Infinito
AddictedToBavarian's Avatar
Portugal
96
Drives: Miss my E92 but love my E46 M3
Pretty cool.
      12-16-2011, 10:15 AM   #3
apc3libras
apc3libras's Avatar
Drives: E36 M3
1999 BMW M3  [4.00]
Awesome.
2007 BMW 328I Monaco Blue /// 1999 BMW M3 Titanium Silver /// 2007 BMW 328I Sparkling Graphite (sold)
      12-16-2011, 10:20 AM   #4
darebornsolja
Drives: 18 F80 [yezy]
2018 BMW M3  [0.00]
Would not mind cruising in that~
      12-16-2011, 10:34 AM   #5
90rr
90rr's Avatar
Drives: 2021 M340i
nice!
      12-16-2011, 11:11 AM   #6
Clifton
Clifton's Avatar
Drives: Cars with tires
Regards,
Clifton
      12-19-2011, 11:29 AM   #7
MoeM3Power
Vago Pirata
MoeM3Power's Avatar
Drives: Voluptuous
Lovin that M5 looks!
      12-19-2011, 11:38 AM   #8
IND-Distribution
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
Im in love!!
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      12-19-2011, 11:39 AM   #9
Adj5633
Adj5633's Avatar
Drives: Screws
I am speechless, great job guys. Very ingenious of you.
      12-19-2011, 11:40 AM   #10
ModificaClassica
ModificaClassica's Avatar
Drives: 2011 BMW 550i 6-Speed Manual
2007 E92 335i  [8.76]
Awesome build! Love it!
      12-19-2011, 11:40 AM   #11
BMWSzabi
BMWSzabi's Avatar
Hungary
Drives: BMW
      12-19-2011, 11:40 AM   #12
Bakeme521
Some say...
Bakeme521's Avatar
Drives: Fresh
2007 BMW 335i  [8.24]
baller status
I have exhaust and an intake...
      12-19-2011, 11:47 AM   #13
ATSR
Drives: 1977 Honda Civic
AMAZING job!!!
      12-19-2011, 11:47 AM   #14
mshab356
Go ///M or go home
mshab356's Avatar
Drives: 2015 F80 M3 6MT
Wow it looks sick right out of paint/assembly when it's plain white with the gold BBS wheels on it!
2015 AB/SO F80 M3 6MT | 19" Black M437 | KW H.A.S. | AutoTechnik Black Front Grills | BMW Performance Side Grills | Painted Front Bumper Reflectors | Gloss Black Exhaust Tips
GONE 2011 SG/Blk E92 M3 CS 6MT
      12-19-2011, 11:55 AM   #15
Vegas_Sirk
Drives: 2013 JKU Wrangler
Such a awesome build!
      12-19-2011, 11:58 AM   #16
Dackelone
European Editor
Dackelone's Avatar
Germany
10539
Drives: N54 e82
I love everything you did! Me wants!!
      12-19-2011, 12:26 PM   #17
Onurleft
Onurleft's Avatar
50
Drives: RPM
This is one of those cars that comes up in my dreams
      12-19-2011, 12:31 PM   #18
Ken@ActiveAutowerke
Drives: various BMWs
wow.. i really really like!
      12-19-2011, 12:32 PM   #19
GoodGuyAvi
GoodGuyAvi's Avatar
1496
Drives: G80
BMW
      12-19-2011, 12:37 PM   #20
Just_me
Drives: RWD
Track: Ring Knutstorp
      12-19-2011, 12:47 PM   #21
GOLFFRR
GOLFFRR's Avatar
10816
Drives: GOLFFRR cart
awesome!
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      12-19-2011, 12:49 PM   #22
M-Power111
M-Power111's Avatar
Drives: Not a BMW....yet
wow very nice work on that, looks stunning!!
BMW=
f30post
