04-28-2013, 12:44 PM | #1 |
Rep 773
IND M-Sport Rear Reflector DIY?
I see all the information and DIY instructions for replacing the front reflectors but after searching for a while I can't find a detailed guide to replacing the rear reflectors especially with m-sport bumper.
Any help is greatly appreciated!
Present: 2019 X3 M40i Phytonic Blue
Past: 2013 335i xdrive Estoril Blue 2011 328i xdrive Black Sapphire Metallic Last edited by fricfracfrank; 04-30-2013 at 11:20 AM.. |
04-29-2013, 03:01 PM | #2 |
Rep 773
Anyone? IND where are you with some help
Past: 2013 335i xdrive Estoril Blue 2011 328i xdrive Black Sapphire Metallic |
05-02-2013, 07:02 AM | #4 | |
Rep 1,053
Pics?
Current: 2021 340xi
Retired: 2018 330xi | 2016 340i 6MT | 2013 335i 6MT | 2011 328i 6MT (N52) | 2008 335xi (N54) |
05-02-2013, 10:24 AM | #5 |
Rep 773
Yea where are the pics...or at least description haha
05-02-2013, 11:52 AM | #6 |
Rep 876
They take 2 minutes to remove. If you are looking at the back of the car there are 3 clips on each reflector. For the first reflector removal I'd lay on your back under the rear of the vehicle (once you do it once you can remove them without crawling under). Press in the clip that is closet to the middle of the car and push outward lightly. This will undue the inside clip, then for the middle clip you have to press down and push lightly. The third clip (the one towards the outside of the car) isn't so much a clip as it is more of a hook to hold the reflector in. When the inside and middle clips have been depressed you can just push on the reflector and it will pop out.
I just pulled mine out a couple days ago to tint them. Did a mock up by putting some clear tape on them and cut that to shape. Then sprayed VHT niteshade to tint them relatively dark. After I reinstalled them I decided it was a little odd looking on my MSport so I simply pulled the now tinted clear tape off and reinstalled the reflectors. I may decide to paint them the same color as the diffuser at a later date. |
05-02-2013, 01:50 PM | #7 | |
Rep 773
THANK YOU! I just didnt want to start ripping them off and ruin anything.
05-04-2013, 06:33 PM | #8 |
Rep 5,373
Did you mean "plastidip"?
///| g87 | f87 Comp | g29 M40i | f97 Comp | f80 Comp | f80 | f30 | e92 | tt | S5 | e92 | 350z | e90 |
05-30-2023, 11:57 PM | #9 |
Rep 14
Drives: '10 528, '13 AlpinaB7, '16 328
Anyone installed LED rear reflectors? pop in just like the red reflectors pop out, but I'm not sure how to wire them up... im assuming to the tail light some how?
05-31-2023, 08:31 AM | #10 | |
Rep 476
2. Are the LEDS COB (diffused light beam over the full surface of reflector) or a single/double string of LEDs along the reflector? Example of double string LED reflector:https://www.aliexpress.com/item/3289...7295074&isdl=y Yes, you will have to wire to the tail lights. If no turns' function, you could wire both LED reflectors in series to one side (left or right). If triple function with turns - then will have to wire to individual sides separately. Post some pics before/after/in operation...
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
04-15-2024, 08:06 PM | #11 |
Rep 292
Drives: 2014 335i 6MT MSport
I know this is an ancient thread, but I tried removing mine tonight (w/M-Sport) and it seems they're snapped into a well molded into the bumper cover as in there's no access to the reflector itself from the back of the bumper cover (I contorted myself quite a bit to reach in there and have a bunch of nice new cuts and scrapes for it), and although I was able to wedge a trim tool under the middle was unable to get it to pop out so I could apply a blackout film.
So how the hell do these come out? There isn't any double-sided tape strong enough to yank these things out based on the fight they put up.
2014 F30 N55 6MT, gray/red, M-sport, VMR 710/Mich PS 4S, MPPK, MPE 2001 E53 M54 5MT peeling green/black, well-optioned |
04-16-2024, 07:46 AM | #12 | |
Rep 476
This is a non-M bumper/reflector shown, but the mounting process is the same:
04-16-2024, 09:06 PM | #13 |
Rep 292
Sorry, maybe I was not clear. I mean the REAR red M-Sport reflectors.
I replaced the amber fronts with gray ones. That was a pain in the ass removing the old adhesive which must be done else the new ones will not sit flush with the bumper cover. Nobody seems to make gray replacements for the rears; I don't want to paint them for insurance reasons and I have a roll of transparent gray film to apply, but I need them OUT to do that!
04-18-2024, 07:48 AM | #14 |
Rep 476
Take a look at the image I've put together for you. It describes removal of the RIGHT side rear reflector:
I had the reflectors out for cleaning while replacing the stock rear diffuser with aftermarket M Performance diffuser. So you might have to take the diffuser out first in order to reach the tabs shown above. The diffuser is easy to remove as it is held in place with a couple screws and plastic pull-out rivets from the bottom and with series of tabs at the top split line. Installation is in reverse order of the steps in the image. Good luck.
04-22-2024, 09:26 PM | #15 | |
Rep 292
04-23-2024, 05:21 PM | #16 |
Rep 93
I just did mine on the weekend and wrapped in black vinyl, for the left side i was easilly able to get my hand behind and push out the clips, for the right hand side i removed the 2 screws of the rear diffuser to the far right, pulled off a couple of the diffuser clips on the right and it was enough to allow me to get my hand behind there and push the reflector clips
05-06-2024, 08:19 AM | #18 | |
Rep 476
Also, wrapped the tail lights with the same film to tone down the red color:
WeAreVenom6.00 |
05-07-2024, 06:53 PM | #19 |
Rep 292
Where did you get the film?
05-07-2024, 06:56 PM | #20 |
Rep 14
