09-26-2023, 08:11 AM | #1 |
Rep 2,434
2011 E92 m3 Competition/Clubsport
41k miles Price: $75k, WILL NOT ENTERTAIN trades or ridiculous offers. Everything you need is here for a fast and reliable dual purpose machine. Drive to the track..Dominate and drive home! Want to make your Corvette and GT3 friends upset?YouTube videos of it in action on track upon request. *Watkins Glen had her consistent 2:04’s and 2:05’s with a passenger *Limerock 58.XX 38 degrees outside temp (NA motors need cold) Don’t want to sell her but I started racing my E36 and need to let some things go for the addiction. E92 M3 Modifications/Chasis: -FULL SPL KINEMATICS -Alekshop Solid rear Subframe Mounts -Alekshop Solid Diff mounts -Front Monoball Bearings Modifications/Suspension: -MCS 2 way Remote Reservoir Double Adjustable Kit from Bimmerworld. (Rebuilt in 2021) by ANZE and raised front spring perch to run 305 front tire on 10.5-11 wide wheel with NO SPACER. -Ground Control Race Camber Plates -Helper Springs with Dividers Both Front and Rear (keeps springs seated when you jack up the) -Hyperco 900/5" Front Springs -Hyperco 1200/7" Rear Springs * Extra Springs rates available -Ground Control Rear Height Adjusters -Rear Shock Mounts -Torrington Bearings on the Front Springs (No spring bind when turning the wheel) -Proper Swaybar Endlinks for these shocks -H&R sway bars front and rear -TRANSMISSION MODIFICATION: -Slon DCT Baffled Racing oil pan -Do88Transmission Cooler Modification/Brakes: -PFC BBK FRONT and Rear (new pads, CASTROL React SRF Fluid and Rotors 3 hours ) -SRF brake fluid -Braided stainless steel Lines -Turner 90mm stud kit - BimmerWorld carbon fiber brake cooling back plates for cooling hose attachment. Modifications/Exterior: - Recently wrapped in custom printed color (Linden Green 4//2023) front bumper, hood, rocker panels protected by clear bra and entire car ceramic coated. Car is Alpine White underneath. -Seibon Carbon Fiber vented hood (vinyl wrapped white to match car) -GT4 front carbon lip -Bimmerworld Carbon fiber Canards -APR GT250 67" Wing -DOWNFORCE USA Rear carbon Diffuser -Pulled rear fenders quarter panels 1” to accommodate wider wheels and tires up to 315 rear tire for street. 305 for track use -CARTEK FIA LED rain/brake light in rear bumper Modifications/Interior: * Interior is Gutted from driver back to trunk. I have some the OEM interior pieces that will come with the Sale of car... Sold many items over the years. -KMP detachable steering wheel (horn & MDM Button programmed) -Swapped double hump dashboard to Single hump - deleted navigation, speaker, stereo, CD changer. -Profi XL seat X2 -Planted Seat Bracket -OEM BMW GTS Harness Bar (Rare) -SCHROTH 6pt harnesses x2 -Gutted back seat/rear -RS red door Pulls -Motorsport24 Carbon Fiber Door cards -SLON carbon fiber rear seat delete chassis enforcement close out panel. Modifications/Engine/trans/diff -K&N cold air intake "gold foil heat wrapped". (Brand new filter Intake) -Do88 OIL, tranny, power steering and radiator coolers -macht schnell x pipe -BIMMERWORLD Magnaflow race exhaust -Epic ECU TUNE -Epic DCT Tune for 3.62 racing Differential -Rod bearings done at 33kmiles -3.62 Diffsonline Bimmerworld Race differential- 10 clutches and custom ramping set up through James Clay in the E92 M3 from the World Challenge competition series *OEM Spare original Trunk lid is included along with OEM High kick Carbon Competition Spoiler * 11/22 I serviced and overhauled/preventative maintenance the car at Autocoutoure - pictures included. Wheels: 1) BBS RIA Motorsport wheels - Diamond Black 18x10.5 square with Hoosier NON DOT Conpetition slicks (2 heat cycles) |
12-23-2023, 03:10 PM | #8 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
Awesome car!
///M Power-Belgium63684.50 |
01-27-2024, 12:13 PM | #10 |
-Frank
498
Rep 687
Nick, interested in selling your E88s?
2005 M3 - SilverGrey/MT - SOLD
2013 E92 M3 ZCP AW/IR-BLK 2022 Ram 1500 Laramie Night Edition - leveled/34s IG: @_frank_stone_ |
01-27-2024, 12:59 PM | #11 |
Rep 2,434
1FastSicilian497.50 |
