04-12-2020, 10:58 PM | #1 |
Rep 384
Best scratch/swirl removal
Looking for some opinions on the best paint scratch and swirl removal product available for some very fine scratches. [IMG][/IMG]After doing some research on a few FB groups I was told that the 3D One, Sonax, Jescar, Griot's and Meguiars Ultimate are some of the best around and according to Amazon they are all rated well with Sonax having the best rating. Anyone have any suggestions?
04-13-2020, 09:52 AM | #2 |
Rep 334
Sonax perfect finish on yello foam pad with DA worked well for me. Beautiful car by the way
NitroBiz147.50 spammysammich1585.00 |
04-13-2020, 10:15 PM | #3 |
Rep 942
A lot of people like Sonax perfect finish with a Meg's MF finishing or cutting disk (depends on how bad your swirls are).
Check out this vid as an example: |
04-14-2020, 12:01 PM | #4 |
Rep 384
How does the Sonax compare to Griot's Garage's products? I plan on buying a orbital polisher and they have a deal for $199 that includes the polisher, two of their products with pads.
BTW....thanks for the vid link! |
04-14-2020, 06:18 PM | #5 | |
Rep 942
The pad type is also very important. I'm sure Griots has some good ones but again I haven't used theirs personally. I'm sure they're fine. Just get the right level of cut for the swirls on your car. I've even used Chemical Guys hexlogic pasa with great results. People also really like Rupes, Lake Country, Meguiars. This all brings up the importance of doing a small test spot on your car before fully diving in. Try a few pad and polish combos and see which results are the most satisfactory, if so, then do the rest of the car |
04-14-2020, 08:08 PM | #6 | |
Rep 384
04-14-2020, 11:12 PM | #7 |
Rep 635
I just went though a big paint correction and CQuarts coating this past week and used Black Fire products. I used Black Fire One Step with a green pad for light scratches and it worked amazing. Check Auto geeks forums for amazing information on detailing.
Ajolives922.00 |
04-15-2020, 11:36 AM | #8 |
Rep 384
Cool! Thank you. I'm starting to believe that everyone is going to say good things about a lot of good products and not one is the very best. I will definitely check out the forum.
04-15-2020, 01:24 PM | #9 | |
Rep 933
Drives: E90 M3
04-23-2020, 12:10 PM | #10 |
Rep 305
If you want PERFECT paint on an M3 here's the recipe (This of course assumes your car is 10ish years old, never paint corrected before and has the swirls and scratches typical of a car this age): (post decon) Sonax Cutmax with URO MF cutting pad. Buy like 4 of them at one go and don't let them get too hot. Prime each pad at the start, and swap them out after every 2x2 area to let them cool off (make sure you have some compressed air and/or a brush to clean them after they've taken their turn. Run your DA at full speed, 1" per second, 4 passes per 2x2 area. Anything other than a scratch through MOST of the thickness of your clear coat is now gone. You'll have a very slight haze but that'll go away on the next step. Come behind it with a URO black finisher pad and the Perfect Finish. 2" per second, 4 passes. Your car now has brand new looking paint. Perfect Finish is an amazing product, and if you can settle with 80% swirl/scratch removal this one product with TWO step MF pad application (still going for the cutting pad first and the finisher second) will get you that. But if you wont settle for anything but microscopically perfect paint you can't leave out the Cutmax. This is only for the hard BMW and Merc clear (I've done it on both) Don't @ me that this is too aggressive for your J car's soft paint. I already know, I have a Toyota for a DD.
04-23-2020, 12:15 PM | #11 |
Rep 305
Obv I didn't include the protection part. I use the same Gyeon surface prep, and then because you've done what I consider a ONE TIME paint correction, you're going to want to not screw around on protection. I do Gyeon MOHS. Can't risk having to do this kind of correction again, ya feel?
04-24-2020, 12:51 PM | #12 |
Stop the hate, get a V8
3851
Rep 8,625
Meguiar's M205 has been one of the most popular products for fine swirl removal for 10+ years. I think that says a lot.
I'd reserve M105 for heavy swirl removal or on paint that has never been polished. No use removing more clearcoat than you have to.
Past: 2011.5 M3 sedan ZCP |
04-24-2020, 01:13 PM | #13 |
Rep 305
Megs 205 is a very fine product, and was able to sit at the top because Perfect Finish wasn't widely available in the US until a few years ago. Still brand familiarity with Sonax isn't nearly as strong as Megs.
04-24-2020, 01:33 PM | #14 |
Rep 384
Speaking of clear coat, I have this "cloud" on my roof that my friend seems to think it was bird poop left on there to long from the previous owner.
04-24-2020, 01:52 PM | #15 |
Rep 1,881
Griots still makes good products, if you dont have a DA polisher, Griots is a good starter unit.
My steps are : Wash -> clay -> wash -> iron-X -> rinse -> dry -> tape off/ remove trim pieces. Then use their Orange med cut pad with Griots BOSS Fast Correcting Cream, followed by the BOSS perfecting cream on a white or yellow pad. This should have you ready for a top coat or sealant of your choice. This should be good enough for most imperfections. For deeper scratches, you may need a heavier cut compound and wool/microfiber pad. But i would start with the steps above and re-evaluate the paints condition, and whether its good enough for your personal satisfaction. The above usually takes me about 18-30 hours depending on how anal im being, and whether its my personal car, or a clients.
04-24-2020, 10:14 PM | #16 | |
Rep 384
04-24-2020, 10:59 PM | #17 |
Rep 31
That looks like bird poo etching in the clear coat. You might be able to compound it out with Meg's 105 or a similar heavy-cut compound. If that doesn't work, wet sanding followed by compounding is the only thing that has worked for me.
04-24-2020, 11:37 PM | #18 | |
Rep 384
I wouldn't know where to start with the wet sanding...could you forward me a link to do that? |
04-25-2020, 03:50 AM | #19 | |
Rep 31
Here's a good video about wet sanding from Larry at Ammo NYC: https://www.youtube.com/watch?time_c...ature=emb_logo |
04-25-2020, 09:39 AM | #20 | |
Rep 942
I was able to remove similar looking bird poo etchings from my wife's car with Sonax Perfect Finish. Try a simple cut polish. If that works - great! If not, then step up to something stronger, and so on. |
04-25-2020, 12:29 PM | #21 | |
Rep 384
Gotcha, that is good advice. My current action plan is Griot's Correcting Cream -> Griot's Fast Correcting Cream -> Griot's Finishing Cream -> Griot's Ceramic 3-1 Wax |
04-25-2020, 10:27 PM | #22 | |
Rep 384
