      02-15-2023, 01:43 PM   #1
Mr. M3
Drives: 2013 M3
hard staining on polished LMs
I've noticed these stain spots on some of my LMs on the polished lips. I've tried sonax full effect wheel cleaner and mother's polish but it doesn't clean off. What can I do to clean these off?
      02-15-2023, 01:59 PM   #2
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
Are the lips bare metal or is there a clear coat? if its bare metal, then a simple mag polish will bring them back to life. if thats not working, then they are etched and a light sanding may be required.
if they are clear coated, then the coating itself is likely ruined and will need to be removed/reapplied or just removed and polished out.
      02-15-2023, 02:24 PM   #3
Mr. M3
Drives: 2013 M3
There's no clear coat just straight polished. Mother's polish isn't doing the job. This is after using mother's polish. That milky mark is still there.
      02-15-2023, 02:25 PM   #4
Mr. M3
Drives: 2013 M3
Here's a pic after polish
      02-15-2023, 02:28 PM   #5
shimmy23
F15 daddymobile
shimmy23's Avatar
2350
Drives: GS X5
you might need to try a light sanding then...
      02-15-2023, 05:05 PM   #6
Mr. M3
Drives: 2013 M3
I've tried sonax full effect cleaner, vingear, clay bar, and mother's mag aluminum polish with no effect. Is sand the only method left?
      02-20-2023, 07:38 PM   #7
Camnyc
wannabe
252
Drives: E90 LCI M3
P21s polishing soap, followed by mothers mag or white diamond
E90 M3 - 6speed - slicktop - single hump
      02-20-2023, 08:36 PM   #8
e92ben
e92ben's Avatar
1053
Drives: BMW M3 BMW 635csi
Looks like metal corrosion. Did you use some cheap wheel cleaner? Like the spray ones? Do you frequently use auto car washes?
e92 ///M3
      02-21-2023, 02:57 AM   #9
Mr. M3
Drives: 2013 M3
Only used sonax full effect cleaner on those.
      02-21-2023, 09:41 AM   #10
tdott
Drives: M3
Polished lips will do that if you let water sit on it for too long.
Once you polish them out, I recommend you ceramic coat the wheels, that will help prevent that, but they'll still require frequent up keep.
I got tired of always cleaning and polishing them, so I got clear coated lips.
      02-21-2023, 10:29 AM   #11
Mr. M3
Drives: 2013 M3
Might be from the storm water during the new year weekend. Gonna try some white diamond on it when I have the chance.
      04-09-2023, 08:43 PM   #12
Throatpunch
Drives: 2008 E93 M3
Mine left hard water spots but i had my polished lips ceramic coated and it doesnt do it anymore
      04-15-2023, 01:44 PM   #13
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
Do not use wheel cleaners and avoid hard water. SoCal is well known for hard water. Get a water softener if you use it to wash your car.
If it is already etched, you will need to get it taken apart, polished and put back together. Probably clear coat the wheels while you're at it.
Auto Detailing Enthusiast!
