F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > 328D N47 F31 Exhaust leak at v-clamp between DPF and turbo
ARMA SPEED
      04-27-2024, 04:24 PM   #1
ahgu
Drives: bmw 328d
I notice the clamp is leaking, I tighten the bolt a little and it did not help.
If I want to replace the clamp and gasket inside , do I need to remove the DPF?
Has anyone done this and can share the experience. I saw the clamp seal is tough, have to align up the flanges properly.
I was thinking maybe the DPF need some cleaning too?
BMW Exhaust Clamp - Genuine BMW 18308512137
BMW Catalytic Converter Gasket - Genuine BMW 18308513651
F31 N47 2015 328d xdrive
      04-27-2024, 09:32 PM   #2
ahgu
Drives: bmw 328d
I think the clamp is not designed properly. the ends on the clamp bends easily and too flimsy for the job. BMW is learning a lot from China on the material quality and material gauge, but not on the price.
I just replaced the plastic valve cover. The plastic crack easily. Even the new ones stored in the warehouse deteriorate overtime. After I solved the oil burning issue, I noticed the exhaust leak. Both are due to cheap material and light duty design.
      05-03-2024, 12:01 PM   #3
speedbirdblack
speedbirdblack's Avatar
Sri Lanka
19
Drives: f30 M-Sport
I remember breaking the clamp when I was removing the dpf. It was flimsy indeed. It was not supposed to be removed, just undo and redo it.
BMW knows how to make money 💰
speedbirdblack
      05-12-2024, 06:18 PM   #4
ahgu
Drives: bmw 328d
How did you remove it? I think I need to use spreader to spread the tabs apart.
The sensor near the other end (band) is tough to remove, do I need to loose the red cable connecting the sensor?
f30post
