05-12-2019, 08:39 PM | #1 |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Hi guys. I've looked far and wide, but it seems no one has attempted this. I was looking to see how feasible it is to buy the M1 and M2 buttons and install them where the blanks currently sit. Pics of buttons below
EDIT: Buttons installed! And they definitely press like the others. But have not doen any wiring. So for now they just look cool. Obviously you would need the M-Sport wheel WITHOUT the active cruise control. Reason i ask is if i can get the button cover to physically press like the rest than I could theoretically sauder into the circuit board behind the bottons and wire that to a remote that controls an aftermarket exhaust valve or meth kit. If u have ideas or have seen someone already attempt this please share. Cheers
Quiet M235i
05-13-2019, 02:14 AM | #2 |
Rep 39
I have thought about doing the same thing, and have looked up what it would cost to buy a spare set of M Sport buttons to cut up and rewire. I'm pretty sure at this point that cutting and rewiring won't be necessary. From the look of the pinouts it should be as simple as popping off the blanks, put in the M buttons, then attempt to tap the LIN port off the steering wheel controller or just tap the CAN BUS of the steering controller. CAN bus would give you more info, but LIN bus guarantees you that the signal absolutely coming from the steering wheel buttons.
05-13-2019, 11:15 PM | #3 | |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
I see what you mean as well with regard to the signal and power wires coming out of the circuit board. Do you happen to know with ones are lin bus and witch ones are can bus?
Quiet M235i
jondagger90.00 |
05-25-2019, 11:48 AM | #4 | |
Rep 68
they mod the M1/M2 botton for exhaust flap control unit |
05-25-2019, 11:51 AM | #5 | ||
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Quiet M235i
jondagger90.00 |
05-25-2019, 11:58 AM | #6 |
Rep 68
this is the guy i get inquiring,although im not getting info for aliexpress
https://market.m.taobao.com/app/idle...5&forceFlush=1 |
EVEda235i90.50 |
07-14-2019, 07:50 AM | #8 |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Good news is the M buttons can be used to replace the blank buttons! Next step is to attempt to sauder into the circuit board behind the buttons
Quiet M235i
jondagger90.00 teachasumthin326.50 |
07-15-2019, 11:14 AM | #9 |
Rep 12
07-15-2019, 04:20 PM | #10 | |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Quiet M235i
jondagger90.00 |
09-08-2019, 11:41 AM | #11 |
Rep 32
Genial,me gustaría poder habilitar esos 2 botones para poder usarlos,si consigue hacerlos funcionar me podría enviar un mp.gracias
09-08-2019, 11:48 AM | #12 | |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Quiet M235i
09-15-2019, 02:52 AM | #13 |
Rep 3
curious to follow this. I'm trying to figure out how to read the button presses coming from these, as well as a few things on the idrive controller. I have access to a CAN feed (tapped into CAN H and CAN L) but am having a tough time parsing the packets. Anyone know where I should go to start looking?
Onizukachan1124.00 |
09-15-2019, 09:01 AM | #14 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
Would be awesome to retrofit the Sport or Sport+ on the M buttons on non M cars.
09-15-2019, 02:35 PM | #15 | |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Quiet M235i
09-15-2019, 02:37 PM | #16 |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
That's next level. Not entirely sure how u could do that yet. Aiming for the meth and exhaust cutout control first
Quiet M235i
09-16-2019, 03:31 AM | #17 | |
Rep 947
Or even replicating the function of the Driving Experience rocker on the Steering wheel would be a step forward for non-M cars. So the top blank for modes toward Sport and Sport + and the bottoms blank toward Comfort and Eco Pro. Almost running the buttons in parallel with the Driving Experience rocker. Could that be possible? |
09-16-2019, 04:51 AM | #19 |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
Correct. In that case this wouldn't work for you
Quiet M235i
09-16-2019, 04:56 AM | #20 | ||
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
This is the remote/relay setup I'm going with. eMylo DC 12V 1CH RF Relay... https://www.amazon.com/dp/B01A6VOH9W...p_mob_ap_share
Quiet M235i
09-16-2019, 07:24 AM | #21 | |
New BMW owner
139
Rep 621
Finding which cable does activate the drive modus up or down for instance. |
09-16-2019, 02:04 PM | #22 | |
Rep 1,509
I wonder if the wiring for ACC is there in cars without it... kind of like the rear fog light switch you can enable by breaking a couple of tabs. That might make it easier to tap into existing wiring and use it for another purpose, instead of running wires as some have suggested. |
