07-05-2022, 11:58 AM | #1 |
Rep 8
Will Style 666 20" fit?
Will oem style 666 wheels fit on my H&R (40/35) lowered F30? The specs on the 666 are:
Front: 20x9J et 29 with 265/30R20 PSS Rear: 20x10J et 40 with 285/30R20 PSS |
07-05-2022, 01:45 PM | #2 |
Rep 4,367
rear may rub under compression
at ET29, outer shoulder of front tire may graze/rub the front part of the fenderwell liner or tab while turning at or near full lock. i'd move the 265/30/20 to the rear and change front tire size to 255/30/20 or 235/35/20. try it out and let us know if it rubs or not. fwiw at 11.55kg and 12.32 kg they are heavy for forged M wheels. with taller wider tires that heighten gearing, add rolling resistance and weight, there will be a more than negligible impact on acceleration and steering. . Last edited by alohasurftoad; 07-05-2022 at 02:16 PM.. |
07-06-2022, 02:05 AM | #4 | |
Rep 8
07-06-2022, 02:32 AM | #5 | |
Rep 4,367
225/35 on 9" will be stretched to the point where if you touch a curb there will be no protection at all. if you are leaving the rear with 285, it would be better paired with 255/30/20. i would try to avoid a 50mm stagger as it increases tendency to understeer in the curves. however if you predominantly go fast going straight only, i suppose it is fine because straight line stability would increase. |
07-06-2022, 02:42 AM | #6 | |
Rep 8
07-06-2022, 02:51 AM | #7 | |
Rep 4,367
your cars fitment will look somewhat like below but your front will be 1mm further out and stretched 1/4" more on a 9". https://f30.bimmerpost.com/forums/sh....php?t=1598356 |
J555568.50 |
07-06-2022, 02:55 AM | #8 |
Rep 4,367
here is the 20" thread
https://f30.bimmerpost.com/forums/sh....php?t=1047084 if you are wondering about 245/35/20 front, it will rub the fenderwell liner at ET29 due to 26.8" height. |
07-06-2022, 03:59 AM | #9 | |
Rep 8
07-06-2022, 04:25 AM | #10 | |
Rep 8
07-06-2022, 07:50 AM | #11 |
Rep 4,367
07-06-2022, 09:14 AM | #12 |
Schmollbraten
12514
Rep 1,985
You want to run the tire/rim dimensions of the M4 comp on your tiny 3 series?
That'll look riced and as already read add some rubber to your wheel wells.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
07-06-2022, 09:33 AM | #13 |
Rep 611
As suggested by alohasurftoad, 235/35 + 265/30 (275/30 for x-drive) is the best you can do. With such low profile, I'd recommend buying some comfier tires - Falken FK510 or 520 are possibly the first choice as more budget friendly, still very good tires.
alohasurftoad3122.50 |
07-08-2022, 12:25 PM | #14 | |
Rep 303
07-24-2022, 02:29 AM | #15 |
Great Teacher
1120
Rep 1,314
Drives: 06 e91 325ix
If you like the look of 666m, Just get the Alzor 19x8.5 et33’s
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
Tags |
666, 666m, fitment |
