09-26-2021, 10:05 PM | #1 |
Rep 708
Ceramic coating wheels / rims
Can you actually ceramic coating rims? How’s the result? Will it require less maintenance? Will water repel more with the coating?
Thanks. |
09-26-2021, 11:11 PM | #2 |
Rep 422
Drives: 2017 F31 328dx
yes you can ceramic coat your wheels and yes it will make your wheels easier to clean and it will have the same affect as it does on your paint so water will bead up on them.
09-27-2021, 08:36 AM | #3 |
Rep 848
Drives: BMW 435i
Agree.
I've coated several sets of wheels on my cars using what was left over from coating my vehicles. It does make them much easier to clean.
Stop by and check out my blog: The Car Geek
09-29-2021, 09:23 PM | #4 |
Rep 113
Yes you can now depending on the brakes you have the longevity can be a issue. I have the m sport brake pack and it generates alot of dust so. I tend to clean more often than most so I get about a summer season before I need a recoat i have only used car pro delux topped with a cermic spray but i may try delux topped with skin see if it gains me some more longevity.
11-05-2021, 03:00 PM | #5 |
Rep 4
Sounds like the a good idea, the quality of the lacquer on BMW wheels is a little lacking in my opinion
Desertnate392.50 |
11-15-2021, 05:28 AM | #6 |
Rep 3,897
Yes, you can! But please note there are ceramic coatings specifically for rims, as the temperature environment is very different there, so the product must be capable of enduring high temperatures.
I have ceramic coated both my sets + the calipers! Very happy with the result! Make sure you use a quality MF towel though, otherwise you will see stripes (did that mistake on my winter set, not a big deal, as you need to look closely to notice them, but annoying).
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
11-15-2021, 07:58 AM | #7 | |
Rep 708
11-15-2021, 08:23 AM | #8 |
Rep 848
Drives: BMW 435i
While you didn't ask me specifically, I've used both CarPro CQuartz UK and CarPro CQuartz TiO2 on my wheels with great success despite neither being a designated wheel coating. UK is still on the market, but TiO2 has been replaced by their new SIC product which I've not yet tried.
Both coatings lasted more than two full seasons of use (I swap winter/summer sets). I either use left over coating from when I've done one of my vehicles, or I'll buy one of the 10ml sample bottles from CarPro which are a perfect size if I'm only coating the wheels.
11-15-2021, 10:39 AM | #9 | |
Rep 1,641
11-15-2021, 01:45 PM | #10 | ||
Rep 3,897
It is recommended by many as the more durable option amongst the wheel coatings. Most of the work is to clean the wheels meticulously. Needless to say - you don't apply coating over dirt. The application itself is easy, my only two recommendations - use a high quality MF cloth and gloves. Don't want that chemistry on your skin.
Desertnate392.50 |
11-16-2021, 08:00 AM | #11 | |
Rep 848
Drives: BMW 435i
Applying a coating like Skyhigh and I mention is different from a spray on/wipe off products which are really just durable sealants and not a high-solids coating. These coatings aren't hard to apply, but you have to understand and follow the application process to get good results. There are plenty of instructional videos available. You don't have to be brand specific since the same technique works for most coatings.
CajunBMW1290.50 |
11-16-2021, 08:05 AM | #12 | ||
Rep 848
Drives: BMW 435i
Good ventilation is usually a good thing too as the solvents in these coatings can be quite strong. CarPro's coatings aren't too bad, but I recently coated my car using a product from a small brand I've never heard of (it was given to me to try out) and nearly gassed myself in my garage. Can't speak of GTechniq since I've never used them.
Skyhigh1908.00 |
11-16-2021, 08:12 AM | #13 |
Rep 3,897
Good point about the ventilation, indeed!
I don't recall but I believe I even used a face-mask during the application. The smell is not that strong, I was doing it in a small utility room (with ventilation) but since I was getting really close to the rims to look from all angles for good coverage, it doesn't harm to wear a mask. I have done waxing without gloves quite a few times (not very clever either), but figured coatings are yet another level of strong chemistry so better be safe than sorry.
Desertnate392.50 CajunBMW1290.50 |
11-16-2021, 08:15 AM | #14 | |
Rep 5,404
Also, ditch the stock BMW brake pads with their sticky black dust. Hawk 5.0 pads have best bite and their dust is light in weight and color. Comes right off wheels! Tip: If you are going to have tires mounted and balanced, do it before ceramic coating the wheels. Wheel weights adhere better if they are being applied on top of a fresh ceramic coat. Hope this helps! |
CajunBMW1290.50 |
11-16-2021, 08:58 AM | #15 | |
Rep 848
Drives: BMW 435i
I wait until the new tires are mounted, and then do a proper, full cleaning of the wheel to include removal of any old weight adhesive and then coat a wheel I know won't be messed with by a tire shop for quite some time. Most tire shops will hit the barrel of the wheel with a shot of some sort of solvent to clean the area below the weights before they stick them on. The last time I can remember a wheel weight coming off was over 15 years ago (maybe 20) when they still used the old-school weights that clamped on to the outside of the wheel.
CajunBMW1290.50 |
11-16-2021, 09:22 AM | #16 | ||
Rep 1,641
11-16-2021, 10:42 AM | #17 | ||
Rep 5,404
Tire weights have adhesive. They will stick better to a wheel that hasn't been freshly ceramic coated. Ceramic coating is designed to prevent things from sticking to it. |
Billfitz8295.00 |
11-16-2021, 12:13 PM | #18 | |
Rep 848
Drives: BMW 435i
johnung4546.50 |
11-16-2021, 12:18 PM | #19 | |
Rep 848
Drives: BMW 435i
I'll take a plastic razorblade (yes, it is a thing) and scrape off as much of the surface material as possible. Then I'll use something like Stoner's Tarminator or Goo Gone (Goof Off works too if you can still find it), the plastic razor blade, and and old rag to remove what ever is left. Many people I've talked to recommend 3M Adhesive Remover as a good choice too, but I already have the Stoner's on hand for tar and other messes.
CajunBMW1290.50 |
11-16-2021, 04:38 PM | #20 | ||
Rep 5,404
Billfitz8295.00 |
11-16-2021, 09:54 PM | #21 |
Rep 16,181
I wouldn't try to put a wheel in the freezer, but a heat gun should soften the adhesive so that it can be easily removed with a putty knife.
11-17-2021, 12:35 AM | #22 |
Rep 5,404
