12-04-2020, 03:29 AM | #1 |
Built Motor F30 340i
407
Rep 257
Blew up 340i (HP50) Transmission
Went to do some 0-60 and 1/4 times tonight and blew up the transmission (ZF8HP50) in my 340i. My main course of action now is doing a HP70 swap into the 340i out of a 535d. I will be fully documenting the swap and posting it here on F30Post as well as B58 Enthusiasts Facebook page. Luckily another user here has already done the swap and also documented it decently well (https://f30.bimmerpost.com/forums/sh....php?t=1663852).
Mods: Pure800, Dorch Stage 2 HPFP, VRSF 4.5" Downpipe, Remus Axleback, Wedge E50 MHD Tune (29psi Boost / 18° Timing). Estimated Power: 650-680whp. 60-130 Time: 6.76s View post on imgur.com
12-04-2020, 07:31 PM | #6 | ||
407
Rep 257
Going to be buying it used. Found one with very low miles (8k miles).
12-04-2020, 09:16 PM | #7 |
Rep 1,362
We play and we pay. It was a good death.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
12-05-2020, 08:51 AM | #8 |
Rep 2,379
Sorry to hear about the failure. Limited torque in 3rd and 6th or full send?
Must be at double the rated torque with those numbers.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
12-05-2020, 03:32 PM | #9 |
Rep 157
12-05-2020, 10:32 PM | #10 | |
Rep 142
Andre was pushing at least high 700s - low 800s for a while on stock zf8hp50 before his went out. Seems Michael just has really bad luck with his car lol. (Jk man, appreciate you pushing the limits! )
2016 340i x-drive M-sport fully loaded. Pure800, Spool fx-150/ethanol analyzer/filter, VRSF catless dp, dinan mid pipe, MST intake, f80paul 93 tune via BM3, XHP, KW Street Comfort, f80 513M with square Michelin as3+ 255/40r18, carbon fiber rear trunk lip, black double slat grill, M-performance interior trim, smoke bumper reflectors.
Jay5k87.50 |
12-06-2020, 01:32 AM | #11 |
Rep 1,449
Was a Pure tranny not an option? B58 King had his trans upgraded by Pure Drivetrain Solutions, cuz mans was pushing 800+ lb-ft lol.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2 |
12-06-2020, 01:40 AM | #12 | |
407
Rep 257
Even with the discount they offered me it's still more than i'm willing to spend right now. HP70 should be more than adequate for the time being.
G.Newt810.00 |
12-07-2020, 07:30 AM | #14 |
Rep 216
now I know the 70 is built to handle more power than the 50 but if there is no tune for the 70 wouldn't you be running the same risk? You'll definitely be well over stock power levels for the 70 and have slower shift times than a tuned 50.
12-07-2020, 08:53 AM | #15 | |
Rep 2,649
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
12-08-2020, 08:49 AM | #16 |
Rep 180
*GC+ he had the big boy. Vargas did give him that turbo for testing purposes mainly to push it to the limit and find out its max potential.
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
12-08-2020, 12:17 PM | #17 |
Rep 179
My transmission is still hanging in there, but has anyone else snapped a diff bolt? Im on my 3rd one...
When I say snapped, yes I literally mean sheared right at the diff/mount point. For reference im running 340i FBO w/ GC currently, dyno 572tq |
12-08-2020, 12:23 PM | #18 |
Rep 216
Not a common problem from what I've heard. You doing some hard launches on a regular basis? What conditions are you in where the bolt breaks?
12-08-2020, 01:22 PM | #19 |
Rep 179
Not really. Both breaks have been under normal driving, however I do use my powerband to its fullest on a semi regular basis.
12-08-2020, 04:03 PM | #20 |
407
Rep 257
XHP has since been made available since the last HP70 swap writeup was done.
TheFanatic113.00 440MIA24.00 |
12-08-2020, 06:01 PM | #21 |
Rep 84
29 psi of boost I wouldn't do a dig and even if I would I'd be in 2nd at least. I'm on 32 psi and break loose in 2nd all the time I try to stay away from 1-2nd gear pulls because you already know the trans will break
12-08-2020, 07:04 PM | #22 |
Rep 216
