E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Windshield washer not working
      05-09-2024, 10:20 PM   #1
bavari
Tunisia
Drives: BMW
I own a 2005 E90 320i. A few days ago, a yellow warning light appeared on my dashboard. Initially, I suspected it was indicating low washer fluid. after few days washer stop working ,When I pulled the lever, there was no response – no fluid discharged, and even the wipers remained inactive ( NB: wipers working when i up or down the lever) At first, I speculated that a safety feature might have deactivated the system due to the fluid being empty. However, after refilling the fluid, the warning light disappeared, but the problem persisted."
i check the fuses and relay everythings looks good
last 7 VIN digits : KP95239
      05-10-2024, 02:19 AM   #2
Lee J. Cook
Lee J. Cook's Avatar
Drives: 1995 Nissan Sentra
Considering the model year of your BMW E90 320i (2005), it's possible that the washer pump itself might need replacing due to wear and tear over time. Additionally, it's worth inspecting the wiring harness and connectors associated with the washer pump to ensure there are no loose connections or damage.
      05-10-2024, 08:07 PM   #3
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
Yeah most likely a bad washer pump. Ireplaced mine as these pumps leak from the bottom nipple. I replaced mine and still have a leak somewhere. Too lazy to gey down there again. 😝
Check for leaks while you there too. The washer fluid tank as it tends to crack and leak fluid.
      05-10-2024, 08:39 PM   #4
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
There is a filter on the pump that can get clogged, it’s a pain to pull the fender liner so I’d just replace the pump and be done with it.
GoRomeo1014.50
      05-20-2024, 07:27 PM   #5
bavari
Tunisia
Drives: BMW
thanks all of you , i will check tomorrow
e90post
